Old 06-21-2016, 06:10 PM   #1
brake light issue
Trailer lights go out when brakes are applied. Lights and turn signals work but everything goes out when brakes are applied.....frustrated!!
mgoulet21 is offline   Reply With Quote
Old 06-21-2016, 06:10 PM   #2
i have a 2006 flagstaff pop-up camper.
Old 06-21-2016, 06:38 PM   #3
Broadway Joe's Avatar
Sounds like a bad ground in the light circuit.
Joe
2015 Wildwood 27RKSS
2015 Silverado 2500HD Duramax
Broadway Joe is offline   Reply With Quote
Old 06-21-2016, 08:00 PM   #4
How do I fix a bad ground?
Old 06-21-2016, 08:37 PM   #5
I would say bad ground wire also.
MtBiker is offline   Reply With Quote
Old 06-21-2016, 09:53 PM   #6
Left Coast
wire brush
Old 06-21-2016, 10:40 PM   #7
Left Coast
Have you tried to activate trailer brakes manually......What happens? And, what's the tow rig?
Old 06-22-2016, 09:55 AM   #8
Head Rambler
Find where the ground wire is attached to the frame of the RV and then see if it's loose or looks corroded. If either of those remove the connector and clean the area well and reinstall it. There may be more than one ground on the frame.
Gotta go campin!
Old 06-25-2016, 10:17 PM   #9
Sham183
Clean the contact area of any and all grounds that are related to your hitch and camper. The area should be free of rust, debris and paint. Reinstall with a new screw or bolt if needed and make sure it is tight. If you still have issues after that you may have a bad connection between the TV and Trailer. Easy way to test the trailer wiring is get a test light probe. About $10 or so and it make life a lot easier to see if you have power from your TV. At the connection point. Inspect all wiring. Possible light bulb being burnt out, or installed incorrect. 1157 bulbs are the 2 fillement bulbs and if one wire breaks or it's put in backwards it will have the same effect as a bad ground. Hope this helps, good luck with the repair.
mopwr4me2003 is offline   Reply With Quote
light, brakes
