There should be a small cable, coming from the tongue area, that you should hook in one of your safety chain hooks. This cable, if pulled on hard enough, will pull a pin, and lock the the brakes, provided the trailer battery is good, in case of a "break away" situation, in which the trailer breaks away from the tow vehicle. In case of a break away. It is a small aircraft stye cable, and make sure you hook it up.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
