Old 07-17-2015, 01:33 PM   #11
clr
Glad that you are in a better place now. It does sound to me like either the ground fault for that circuit or the converter is bad. Just remember you are running on the battery for the lights and water pump now so take it easy on usage and you will be fine. Enjoy your camping trip.
clr is offline   Reply With Quote
Old 07-17-2015, 02:05 PM   #12
delb2917's Avatar
What about the air conditioning? Is it on shore or battery?
delb2917 is offline   Reply With Quote
Old 07-17-2015, 02:06 PM   #13
delb2917's Avatar
Im thinking about butting the battery charger on the battery the rest of the time im here. Should be ok to do that.
Old 07-17-2015, 02:20 PM   #14
brookstone345sa's Avatar
If you can get to converter, check it for its own fuse. Mine has a fuse on the side
brookstone345sa is offline   Reply With Quote
Old 07-17-2015, 02:23 PM   #15
clr
The AC is on the 120V shore power so no problem. If you have the output of the converter going to the battery off due to the AC breaker for the converter being open it is fine to just leave the battery charger on the battery. That way you would not need to worry about running down the battery.
Old 07-17-2015, 02:48 PM   #16
delb2917's Avatar
Thats what I was thinking.
Brownstone. I do have fuses on the right side. All of them are good. They have a red light on the side of them if they bust. All lights are off and I check everyone of them. All good. I still dont have the breaker for the outlets on.
Old 07-17-2015, 03:00 PM   #17
Who Dares, Wins
doc73's Avatar
May not be the issue but I had an issue in a previous trailer where the breaker kept tripping for no real reason. Turned out the breaker was bad, a trip to HD and I was back up and running.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 07-17-2015, 03:15 PM   #18
Flybob's Avatar
Do you have any AC outlets in the PU that are not working now that you have some power. Most TT have multiple AC outlets connected thru one GFI outlet. If that one has tripped, it could trip the master breaker. If you have an AC outlet on the outside of the TT then you have a GFI outlet somewhere Usually near sink, bath, kitchen or outside.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-17-2015, 03:28 PM   #19
delb2917's Avatar
Another question. How do I use my propane to the fridge?
Fly bob...I do have another outlet outside. Im going to see whats up with that. Thanks. I will get back to you.
Old 07-17-2015, 03:40 PM   #20
delb2917's Avatar
Doc. I think you might be right. I will have to wait till im back in town to try that. Thanks man.
breaker
