Old 10-14-2014, 02:53 PM   #11
msantos's Avatar
Hey if the camp grounds offer it why not use it
msantos is offline   Reply With Quote
Old 10-14-2014, 02:55 PM   #12
Do you have a shore power port, or just a door that the shore power comes out of? If so run it along side that.
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 10-14-2014, 03:07 PM   #13
msantos's Avatar
Paul I have a door it comes out of
Old 10-14-2014, 03:50 PM   #14
Terier's Avatar
Originally Posted by msantos View Post
Jackfrost I am trying to make it like the Hilton
Good reply. I too like some comfort of home. I camp solo so it can be nice having some communication going on even if it's only one way. The campground I'm heading to on my next trip has cable and I do plan on using making use of it. There an antenna booster in my TT so I will need to turn it off when connected to cable.
Old 10-14-2014, 08:44 PM   #15
msantos's Avatar
Yeah I hear ya terier
Old 10-14-2014, 09:26 PM   #16
Ret E-9 Anchor-clanker
donanddona's Avatar
JackFrostwinter, I hope the hot rod is running. With the snow around it, it should be covered. Like... it's nice ya know.
donanddona is offline   Reply With Quote
Old 10-15-2014, 06:47 AM   #17
vinmaker's Avatar
With all connections, the fewer times you change wires the better. So if you can run a cable direct from the campsite pole to the TV your better off. Coaxial cable is thin and can easily slip up and under the tenting to snake inside. I recommend you pick up a length of cable and just fish it into the pop up and hook it directly to the TV. The signal strength would be the best you can get from the pole.
My camper is wired with an external cable hook up but I still bypass it and feed it into the camper.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 10-15-2014, 07:32 AM   #18
Herk7769's Avatar
Does your pup have a roof antenna (like a Winegard or Jack)?
If so, you can retrofit the roof/cable wall plate and add a single coax connector to an outside wall.
Otherwise carry a long(er) coax cable and run it into the TV as previously suggested.
HAM CALLSIGN - KC3FFW
Old 10-15-2014, 08:00 AM   #19
msantos's Avatar
No antenna but I think running under the bunk is a good idea
Old 10-15-2014, 08:10 AM   #20
mark0224's Avatar
There are as stated cable tv connections like this Amazon.com: Prime Products 08-6215 White Weatherproof Cable TV Kit: Automotive and yes they can get corroded but won't if you use di-electric grease on them. The only thing with these your going to have to at least drill a hole in the side of your camper. The easiest way with yours also as stated would be slip a cable under the canvas. I usually use my antenna but have been to a cg that had cable free for my site and you couldn't get anything on the antenna so I used it. Having the tv for morning weather , news and to catch that show that when you miss one in the series are a great thing. Great on rainy days too.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
