Old 06-07-2016, 05:11 AM   #1
Camper top not up all the way
Picked up my brand new Rockwood 2716G , drove it home about 225 miles ,went to set it up and the power winch stops about an inch from the top and now the door doesn't fit. All worked at the dealership. Did some research and it looks like the limit switch needs to be adjusted. Could it be the switch adjustment moved on the drive home. Thanks in advance , any help would be appreciated. Thanks Frank
Frankiebaby is offline   Reply With Quote
Old 06-07-2016, 06:38 AM   #2
Head Rambler
The switch setting could have moved, but if it did something is loose. Have you opened the cover and looked to see what happened?
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 06-07-2016, 07:03 AM   #3
Anything is possible with our PUPS. Make sure you are level, height cable is tight but not to the point the screws holding cable will come out. If cable is not tight than you limit switch may need adjustment. The more you use you camper the more things you will learn about it and make mods to it.
Hope this helps, enjoy your new camper
JPBar is offline   Reply With Quote
Old 06-07-2016, 07:58 AM   #4
Thanks, didn't have time last night to open the cover for visual inspection, gonna do that after work today. I feel confident that it's the limit switch as the pop up was level all around. I'll let you know how I make out.
Old 06-07-2016, 08:02 AM   #5
We just had the same thing with our classic 625d. The wire wasn't taught, so after two tries on the limit screw, and it is perfect. Good luck and enjoy.
Mark
Dodaman is offline   Reply With Quote
Old 06-07-2016, 11:42 AM   #6
REV
Must be contagious my hw276 did the same thing last week. Worked fine at home then during setup at campground wammo wouldn't raise high enough. Thank God the rain stopped was almost ready to break out the plastic bags and duct tape...lol fairly easy repair and added a little blue loctite hopefully that holds.
REV is offline   Reply With Quote
Old 06-07-2016, 02:57 PM   #7
Thanks for all your replies, hope to post the eagle has landed , not Houston we have a problem. Thanks to all.
Old 06-07-2016, 05:38 PM   #8
thanks to all, the eagle has landed and all is well. It was a simple adjustment of the limit switch. A 4 mm allen wrench and a few tries and up she went. Thanks again to all.
Old 06-07-2016, 06:11 PM   #9
Glad it was a simple fix, now you can put that fix in your book of knowledge.
Happy Camping!!
Old 06-08-2016, 11:45 AM   #10
Head Rambler
Thanks for coming back and reporting what the problem and fix was. It helps us all to know what fixed it.
Gotta go campin!
camper
