Old 06-19-2014, 04:41 PM   #1
troutstalker's Avatar
Cassette toilet
For those that have a cassette toilet, I have a question. Can I fill the reservoir tank before I leave for the trip or should I wait till I get to the destination?
Is there anyway that bumping around on the Road or going uphill might cause it to spill. I am not talking about filling up the toilet but rather the cassette toilets reservoir.
troutstalker is offline   Reply With Quote
Old 06-19-2014, 05:06 PM   #2
Blackrock's Avatar
Kept mine full all the time when I had a pop up with one.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Illegitimum non carborundum
Blackrock is offline   Reply With Quote
Old 06-19-2014, 07:28 PM   #3
Trout, The book says to fill it either half or 3/4 full, can't remember which, for just that reason. That said, I've traveled with it full, and I've traveled with it half full, over some fairly tough terrain, and I've never spilled a drop from the reservoir tank.
sratliff is offline   Reply With Quote
Old 06-19-2014, 07:30 PM   #4
And use it! That's what it's there for!
Old 06-19-2014, 11:36 PM   #5
Thanks all for the information that helps much.
Old 06-20-2014, 10:56 AM   #6
tjcreed's Avatar
toilet pump
I have a thetford C403L toilet with electric flush. problem is the impeller in the pump sticks after a few days of none use and blows the fuse. is there a fix for this? So far I have had to take the pump out and use a pick to rotate the impeller a little to free it up and then replace the 3 amp. fuse.
tjcreed is offline   Reply With Quote
Old 09-04-2014, 11:50 PM   #7
We have just bought a rockwood with cassette toilet. Question to Troutstalker - How does one get the chemical to release inside? we've pressed the lever inside and chemical is not coming thru. What are we doing wrong? Hope you can help us..
Eleanor is offline   Reply With Quote
Old 09-05-2014, 07:44 AM   #8
Hi,
I don't know wich model you have, but on mine, I have to push the blue spot near the inside lever to get the liquid. Unlike other toilets connected to the water, it's not the flush lever that activate the liquid.
Does-it answer your question?
2007 Georgetown 338
2012 Rockwood Freedom 1950 Pop up (Sold)
1997 Skamper 17A (sold)
1969 Starcraft Starmaster 6 (when I was a kid, it made me say: "One day I'll have my own")
Jiheme is offline   Reply With Quote
Old 09-05-2014, 11:10 AM   #9
Cassette Toilet
Thanks for the replies received on operation of cassette toilet. Jiheme yes we know the blue button is supposed to release chemical/water but ours is not doing so. Now upon reading various articles maybe we did not fill with enough water. As it was working well the previous time. In the manual it only states to fill to reservoir line but on forum others state that you keep pouring (which we did not do). Also how did you winterize the cassette toilet to make sure no water is in reservoir?
Old 09-05-2014, 11:11 AM   #10
re Winterizing Rockwood popup 2008 trailer
Could not find the site that shows or states how to winterize. Any info appreciated. Thanks
Old 09-05-2014, 11:27 AM   #11
Hi,
From what I read on the user manual of the toilet, to empty the reservoir, you have to use the hose that also is used as water level indicator; it can be used to drain the liquid.
Read the manual from this link:
C402C and C403L Cassette PDF
Personally, for winter, I'll add some plumbing anti freese in the reservoir and activate the pump to see the liquid go thru. Like that I'll be sure there is no water left to break it.
2007 Georgetown 338
Old 09-09-2014, 06:37 PM   #12
On one trip, something was bouncing around and would push the pump button. Enough to partly fill the bowl and cause the blue water to splash around and out of the bowl while driving. The circuit must energize in my popup off the tow plug.
Seperate point, regretfully we do not get enough
pro97 is offline   Reply With Quote
Old 09-09-2014, 06:39 PM   #13
Use out the our camper so rather than filling the tank with water, we use pink antifreeze with the blue chemical so we do not have to drain it. It makes a pretty shade of purple
