Old 03-06-2015, 01:09 AM   #1
Charging
Hi all, I have an 2010 rock wood 1950 I just bought and will be taking out soon. My question is if I hook my camper to a electrical hook up (30amp) will it also charge my deep cycle battery? Thanks in advance.
dcoleman is offline   Reply With Quote
Old 03-06-2015, 01:31 AM   #2
Mojojojo's Avatar
Yes it should as well as keep the 12volt stuff running on the plug not the battery
My wife keeps saying I don't listen to her -Or something like that?...."My advice has no basis ,more reliable them my own meandering experience" Baz Luhrmann
2011 Sierra 355QBQ 1986 F350
Mojojojo is offline   Reply With Quote
Old 03-06-2015, 06:05 AM   #3
Yes. And you'll probably want to check to see if your towing vehicle is wired properly so it's being charged while traveling. That way if you wanted to use frig. it won't drain it.
Sent from my iPhone using Forest River Forumsdaverobenolt
daverobenolt is offline   Reply With Quote
Old 03-06-2015, 06:44 AM   #4
wmtire's Avatar
Good question:
Mark Polk has some very informative articles that explain the RV electrical system and the converter (which is also your battery charger) that you may want to read.
Basic RV Electricity - RV Information (RV Maintenance)
RV Converters and Amp Draw - RV Information (RV Maintenance)
2011 Flagstaff 831 RLBSS
Old 03-08-2015, 11:06 PM   #5
Thanks all info was great, much appreciated.
charging
