Old 09-28-2014, 03:33 PM   #1
vinmaker's Avatar
Compression switch on pop up roof. ??
While taking down my roof yesterday I noticed what looked like a compression switch (not sure if true name of it) mounted on the inside of the roof (front drivers side) so that it would compress once the roof touched the sidewalls when closed up.
Does anyone know what it does? It seems to me it would be a safety switch. But I cannot figure out what it is protecting if the roof is down or if it activates when the roof is raised and the switch extends what it would protect then as well.
Thoughts?
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 09-28-2014, 04:14 PM   #2
raspivey's Avatar
Probably serves the same purpose as the switches under the galley on most popups. If memory serves, the 296 galley doesn't swing down. Probably kills the lights when the top is down. Try pushing it with the lights on and see what happens.
Old 09-28-2014, 05:17 PM   #3
raspivey, the pup should have a master switch for the main power on the cabinet. not sure what it does vin ill look at my hw276 to see if i have one too. the rv show is here in michigan so if i make my way there this week ill ask a demo person . hope all turned out for you and that youhad a great time. pic of the switch if you could.
kinma13 is offline   Reply With Quote
Old 09-28-2014, 06:05 PM   #4
raspivey's Avatar
I follow you there, but what I was talking about was the disconnect for the lights to keep you from leaving them on accidentally when you put the top down. On models with the fold down galley, it's normally under the sink. When the sink flips / swings up, the button gets pressed.
Old 09-28-2014, 07:27 PM   #5
X2 on raspiveys' above post. You don't want power to the lights and accidently have them on when folding up. The heat from the lights could start a fire on the folded in tent end material.
Old 09-28-2014, 07:46 PM   #6
raspivey i agree with you on a low pup, i was told (by dealer) the hw dont have that but im thinking they mayber wrong cause that the only thing that make sense.
Old 09-28-2014, 11:57 PM   #7
whatachump's Avatar
Saftey switch for the lights as stated above. Replaced mine last winter.
whatachump is offline   Reply With Quote
Old 09-29-2014, 07:26 AM   #8
Im not sure because when my pup is closed but I have the door open I can still turn the lights on using the main switch but mine is a high wall if that matters.
Old 09-29-2014, 09:34 AM   #9
Take The Road Less Travld
MuddauberE's Avatar
Vinmaker
I had the same switch in my 2007 rockwood HW popup. It was the kill all switch that ran the lights on the roof. The only thing it did not control was the AC but it had to be plugged in using the port on the back side of the roof anyway.
"Take The Road Less Traveled"
2013 Rockwood Roo 233s
2017 Ford F-150 EB
I've been an RVer since 2007, Lifetime Camper
Gotta love the Outdoors, Disconnect and Enjoy Nature!
MuddauberE is offline   Reply With Quote
Old 10-02-2014, 07:08 PM   #10
well got my pup back so i raised the top and opened the door then lowered the top and guess what no lights!! guess my dealer was wrong saying if i leave the main switch on the lights would drain the battery.
pop up, roo, roof
