Old 08-26-2016, 11:49 AM   #11
Left Coast
And the trap under sink, if your unit has a sink...
Old 08-26-2016, 12:48 PM   #12
Ok thanks. I'll be sure and use it. We get a few really hard freezes so I'm pretty sure it would be necessary in my area.
Sent from my SD4930UR using Tapatalk
2016 Salem Cruise Lite 261bhxl
Ram 1500 5.7l Hemi Crew Cab 4wd
gspot01 is online now   Reply With Quote
Old 08-26-2016, 01:39 PM   #13
Recently new!
Paulie1138's Avatar
Send a message via AIM to Paulie1138
Winterizing
Just a fast note to the newbies! use anti-freeze designated for RV use-not your vehicle radiator! Yes, there is a difference! One can kill you, the other, just a bit unpleasant tasting!
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14
2001 Ford F-250 7.3
A Loving wife and Mason the always dirty dog!
Paulie1138 is online now   Reply With Quote
Old 08-26-2016, 03:07 PM   #14
NMWildcat's Avatar
Here's the plastic blow out (one way valve) plug used with a compressor I was talking about for about $2. You can also get a brass one at Home Depot for about $8. Makes the job much easier!
Blow-out Plug - Camco 36104 - Winterizing - Camping World
Scott and Liz - Southern NM
Old 08-26-2016, 03:15 PM   #15
Georgia Frog Rally 2017
aceinspp's Avatar
You can buy at Walmart for about $3.00. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped so far 2017 15
Days booked so far in 2017 37
aceinspp is online now   Reply With Quote
Old 08-26-2016, 03:56 PM   #16
I use the brass version and just use the clamp on air chuck from my bicycle pump.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 08-26-2016, 04:07 PM   #17
These are NOT one way valves, they're basically just "reducers;" (at least, mine's not, and it looks exactly like your pic).
2011 Traverse LT, 3.6L, FWD
Old 08-26-2016, 04:48 PM   #18
NMWildcat's Avatar
Don't know what you have, but the ones I use let the air in and then hold the pressure until I open a faucet. Can't remember where i bought mine. Is possible that the link I grabbed is not the exact one I have but looks the same.
Old 08-27-2016, 09:45 AM   #19
TARVIDSON
winterizing
I use the small compressor like you do, the trick to really getting enough water out is to keep the pressure on, not over 40#, let it build up, release one valve at a time and keep repeating until you are getting pretty much nothing but air. Don't forget to run the pump dry a couple times. Don't forget toilets, outside showers etc. Using this method I have never used antifreeze except down the drains and in the black and gray tanks, never a problem.
TARVIDSON is offline   Reply With Quote
Old 08-27-2016, 10:55 AM   #20
I was told that it's better to pump antifreeze thru the entire trailer. The trouble with air is if there's a low spot in the piping (and there's probably plenty) the air will just blow by & the pipe can still freeze. Of course you have to turn the by pass on the HWT. HWT's don't like antifreeze. Also pull the electric anode after doing the bypass & dump all the water in the HWT.
Ian Walker is offline   Reply With Quote
pop up, winter, winterize
