08-27-2016, 10:58 AM
#21
It's really not the air pressure that moves the water out, it's the air FLOW. As soon as you open a faucet, pressure drops very quickly, unless you have a VERY large capacity compressor and/or air tank.
2011 Traverse LT, 3.6L, FWD
08-27-2016, 11:18 AM
#22
Thus the reason we all say 'REPEAT'
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
08-27-2016, 01:13 PM
#23
My point is that you don't need a check valve to " hold" the pressure.
08-27-2016, 01:25 PM
#24
And my point it that it sure makes it easier to do it by yourself.
08-27-2016, 03:34 PM
#25
Then yours must attach to the air hose. Mine does not.
08-27-2016, 04:14 PM
#26
LOL!! Neither does mine....
08-28-2016, 09:33 AM
#27
TARVIDSON
winterizing
If I missed something, excuse me, but the little part that connects your air compressor to the city water connection is available at most any RV parts counter for under $10 so your compressor stays hooked up and running while you go around opening and closing valves.
08-28-2016, 10:09 AM
#28
It takes 2 gallons of anti freeze to do the lite, so I do not bother with the air.
08-28-2016, 10:14 AM
#29
Mine has no way to leave the air hose connected unless someone stands there and holds it. I use the rubber tipped blow nozzle to pressurize the system. Guess I could get brass fittings and rig it with a quick release but just never needed to. The whole process takes about 10 minutes.
08-28-2016, 10:29 AM
#30
We don't really have winter so we still use ours during the winter months. We just blow it out between trips and don't mess with antifreeze.
