Old 07-15-2018, 08:47 PM   #1
jwh4984's Avatar
Condensation
Due to the hot day temps and cool night temps in Michigan upper peninsula we experienced condensation on the inside of both bunk ends we had the screens open on each end with the fan on any other ideas to prevent this again or is it just the nature of the beast with weather like that
jwh4984 is offline   Reply With Quote
Old 07-15-2018, 08:52 PM   #2
Flybob's Avatar
Be sure to check under the mattress. If you get condensation, just add a sheet of foam home insulation board between mattress and bed base.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-15-2018, 09:05 PM   #3
bikendan's Avatar
Did you use Popup Gizmos?
Equalizer WDH
Old 07-16-2018, 01:14 PM   #4
jwh4984's Avatar
Do the gizmos work for condensation normally it's not an issue but there were a couple of humid days I thought about running the AC ????
Old 07-16-2018, 03:28 PM   #5
bikendan's Avatar
PUGs offer so many benefits, including reducing condensation, it's a no-brainer.
#1 mod for popups and hybrids.
Equalizer WDH
Old 07-17-2018, 07:29 AM   #6
Amartin453's Avatar
I have the Gizmos and they due reduce the heat inside the pup significantly, while blocking out the light in the early morning. Iíve not had any condensation on the inside of the pup but did have it directly under the Gizmo.
Amartin453 is offline   Reply With Quote
Old 07-21-2018, 03:08 AM   #7
Get a vent fan cover and that way you can open the vent even during rain. We open the screen door panel at the top too.
kinma13 is offline   Reply With Quote
