Old 09-20-2011, 07:27 AM   #11
Hi
Originally Posted by herk7769 View Post
This is absolutely true and is included as a note in most of the manuals.
In fact with the TriMetric TM-2025RV monitoring the battery you can watch the amps go from positive to negative when you use a slide switch.
The battery is maintaining the voltage while the supplying the amps to move the slide.
The battery monitor circuit in the converter will shut it down when battery voltage drops too low.
WFCO - New world of power ideas - Why is there no power?
Another answer to a frequently asked question here.
WFCO - New world of power ideas - Can I use any battery with WFCO chargers?
I read your replies here often and thank you as you have great knowledge on most of the issues raised and produce very informative correct answers. Thanks
goody59 is offline   Reply With Quote
Old 09-20-2011, 07:50 AM   #12
dretired's Avatar
Make sure your battery connections are clean and Tight .. I had sporadic on/off issues with a water heater on my first trip this spring..sure enough..loose ground connection at battery terminal !!
dretired is offline   Reply With Quote
Old 09-20-2011, 07:58 AM   #13
Herk7769's Avatar
Thank you Steve,
I try to be as complete as possible; with links to additional or supportive information. Sometimes I get tripped up by all the various models of appliances and camper types; but I am still learning from every one here. I love sharing what I have learned as do all the contributors.
Hopefully soon; it will be you!
HAM CALLSIGN - KC3FFW
battery
