Old 09-25-2014, 08:38 PM   #1
vinmaker's Avatar
Do you use shore power to run the powerwinch?
I came across a thread of Coleman owners who said that there units had a sticker on them that said to only use 12V DC to operate the power lift and not to use shore power as it could damage the unit.
I have always plugged it in so as not to drain the battery and to provide needed juice. Am I the only one that does this?
Should I be bringing a battery charger with me to provide the extra juice?
Thanks,
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 09-25-2014, 08:55 PM   #2
deartruc's Avatar
Shorepower. The jack is 12vdc and is wired to the battery. You aren't going to give it more than the 13.x volts the converter is going to provide.
2017 GMC Yukon
2015 Roo 23 ikss
deartruc is offline   Reply With Quote
Old 09-25-2014, 09:40 PM   #3
GalsofEscape's Avatar
Thanks,
Vin.
Why would you need a separate battery charger when you have a 3 stage converter that will charge the battery when you have shore power?
I usually lift the roof before plugging into shore power, for no particular reason other than that is my routine. and I don't think it makes any difference, the power for the winch comes from the battery regardless of whether or not the camper is plugged into shore power or not.
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is offline   Reply With Quote
Old 09-26-2014, 07:09 AM   #4
vinmaker's Avatar
This is a pic of the sticker. It may only apply to the Barker power lifts on the Coleman/Fleetwoods but made me thing of power lifts overall. It mentions the converter.
Name:	Lift warning.JPG
2015 HW296
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 09-26-2014, 07:18 AM   #5
Taranwanderer's Avatar
I think what this sticker is saying is "don't use the lift unless you have a battery installed," ie, don't take the battery out and then try to use the lift with just the converter's output, as it won't be enough (which I find hard to believe, but whatever.) The lift motor is getting 12v from the battery, so why would it matter if the converter was plugged in charging the battery or not? That's the only explanation that makes sense to me... Coleman needs to explain this a little better, IMO.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 09-26-2014, 07:51 AM   #6
jonrjen's Avatar
I would say that that sticker is a kind of a redundant but obvious sticker that you find now required by the legal department of so many various manufactures.
Kind of like the "Warning Label" on a jar of peanuts that states that there may be peanuts or peanut by products used when making this item. WELL, DUH I would sure hope that there was,
2013 Ford F350 FX4 4x4 PSD
2013 Wildcat 353LS
2015 Day/Nights Camped 5
2014 Day/Nights Camped 29
jonrjen is offline   Reply With Quote
Old 09-26-2014, 07:58 AM   #7
Brother Les's Avatar
Thanks,
Vin.
Look at the sticker in post #4.
The 'plain English', (which is confusing by the sticker) is that there must be a GOOD battery installed on the unit in order to have the full 12v umphff to get the power lift going. A camper 'Can' (not recommended) use some 12v applications with out a battery installed by getting the 12v voltage from the converter (a couple of 12v lights and/or the radio). Some systems will not 'start' because the 'converter alone' will not be able to have the required umphff (full 12v) at the beginning of the requirement.... Your converter is 'on' a trickle charge (2v?) mode and as a requested drain off is detected from the battery the converter can/will go to a higher charge (for the battery) mode of around 14.0v. So, you can not run your power lift OR your heat furnace with out a good battery. If your battery has bad cells or a short, you 'still' may not be able to run your power lift, slide outs, and/or furnace your furnace.
Brother Les
Old 09-26-2014, 03:12 PM   #8
vinmaker's Avatar
Thank you brother Les. That makes sense.
I always do have the battery charged up before every trip and hooked up for the tow in. I then back in, level and plug in so I can raise the roof and get the fridge going.
Sounds like all is well. Thanks.
Vin.
2015 HW296
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 09-26-2014, 03:17 PM   #9
Vin.
All is well
Brother Les
Old 09-27-2014, 08:49 AM   #10
f5moab's Avatar
Low voltage is like a brown out to the electric motor. SO if the the battery is dead, the converter might supply enough for the motor to turn, but not enough for it to turn as designed; thus creating heat and damaging the motor. Whereas a dead battery won't do a darn thing.
And a good battery charger is a lot better than the charge provided on one of the WFCC converters normally installed on these popups.
f5moab is offline   Reply With Quote
power
