Old 04-11-2014, 12:15 PM   #11
delb2917's Avatar
The reason i asked was because the other picture you took of the water hookup, you should buy a cover for the vent. It keeps bee's and chipmunk out of it. Her is what I'm talking about. Just giving a heads up.
Sent from my SCH-I535 using Forest River Forums mobile app
delb2917 is offline   Reply With Quote
Old 04-11-2014, 12:21 PM   #12
delb2917's Avatar
Old 04-11-2014, 12:23 PM   #13
loobdyloo5's Avatar
Oooh. Gosh never would have thought of that! Thank you. Where do I get that from?
loobdyloo5 is offline   Reply With Quote
Old 04-11-2014, 12:25 PM   #14
delb2917's Avatar
Wal-Mart or gander mountain. It was around 7 bucks I think.
Old 04-11-2014, 12:26 PM   #15
loobdyloo5's Avatar
Ok thank u, I'll look tonight
Old 04-11-2014, 12:58 PM   #16
loobdyloo5's Avatar
Ok next question. We filled the tank with water and 2 oz of bleach. I think the manual said to drain the water after 3 hrs. So now both pipes are uncapped. The kitchen sink, and the pipe from the shower. What am I looking for to drain the water? Is there a switch? Or is there something I turn, that would b near either if these pipes?
Old 04-11-2014, 01:21 PM   #17
There should be a freshwater drain under your RV. They are usually marked. There is also on most RV low point drains. There should also be a drain for your water heater. If you drain the water heater, make sure it is not powered on...
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 04-11-2014, 01:31 PM   #18
loobdyloo5's Avatar
Not sure if it's the water heater. But I found something underneath. It is not marked, or that I could c. I don't think it could have been in a more inconvenient location! : /Click image for larger version
Name:	ImageUploadedByForest River Forums1397241093.907875.jpg
Old 04-11-2014, 01:40 PM   #19
Usually the water heater hose is red. Cold is blue. It does look like a drain valve. Turn it on, feel the water temp to determine if it is hot/cold. Watch your water level gauge and it should start showing the tank emptying.
2016 Siverback 33IK
Old 04-11-2014, 01:44 PM   #20
PS.. It takes a long time for the tank to drain. I would suggest that you open your grey water valve (I'm assuming this is a new unit) and turn on your sinks and let the water drain onto the ground/driveway. This will also sanitize you plumbing to your faucets.
2016 Siverback 33IK
