Old 07-28-2014, 09:35 PM   #21
VinceU's Avatar
Originally Posted by vinmaker View Post
It looks like it might have a hole in it as well? Wonder if it is a catch drain for any water that might get under the slide.
Vince. How do we know it is waterproof glue? Is it special RV wood sheets? This is scary. I too would like to undercoat mine but what about trapping moisture in? Wood and water is tricky.
Best way to see is to look up "OSB board" on line and read the Wik explanation. They have been using the outdoor variety for many years on RV's, trailers and M/Hs. Lighter and sometimes stronger than similar size plywood. If it weren't waterproof, RV's would self destruct in 3 years or less.
Old 07-28-2014, 10:15 PM   #22
Anyone that wants to undercoat the pup. You might want to find out how that would affect the warranty. Mine is a 2015 hw 276 that has a 25 yr warranty so in my case I think they would screw me if anything did happen. Ill be leaving it till the warranty is up then LINE X the underneath.
kinma13 is offline   Reply With Quote
Old 07-28-2014, 10:18 PM   #23
Fishhawk. So far I should be able to connect a 3" stinky to the bayonet fitting. Ill post better pic and part numbers as long as it works. So far it should but that box is stopping me but I figured out a different setup that should be ok and not run in to any problems.
Old 07-28-2014, 10:45 PM   #24
I correct my location of the box. Its at the grey drain outlet which is behind the slide which is the shower floor so im thinking a P trap for the shower? Might look tomorrow.
Old 07-28-2014, 11:45 PM   #25
It's a box that protects the Ptrap for the shower. Some units have plastic boxes and some have ⅜" OSB.
IonicBrick is offline   Reply With Quote
Old 07-29-2014, 05:01 AM   #26
Incheon, S. Korea
BigBaron's Avatar
F5Moab-you're twisted... LOL
Do not undercoat the plywood! It's open so that moisture can escape. If you undercoat it, any moisture that gets in will trap against the coating (think rubber mat on concrete) and the floor will fail.
FWIW I used to be a waterproofing contractor.
Me, Julie, Lil' Barry, Faith, and OSDs, Fang and Treaty
2003 Hyundai Starex (H1), 2012 Coachmen Clipper 126
I don't know when we'll be able to go camping again...
BigBaron is offline   Reply With Quote
Old 07-29-2014, 06:43 AM   #27
Dodge Guy's Avatar
Originally Posted by anaro View Post
You mention it is located below the slide, could it be protecting or housing a slide out motor?
That`s my guess!
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 07-29-2014, 06:44 AM   #28
IonicBrick does that mean I might be able to access the black tank? Dont think I can though.
Old 07-29-2014, 09:01 AM   #29
No...The drain for the shower is plumbed into the grey water tanks.
Old 07-29-2014, 05:41 PM   #30
GalsofEscape's Avatar
Originally Posted by Dodge Guy View Post
That`s my guess!
nope. pups do not have slide motors, it be all manual brute strength....
I got curious so now I am home and looked under my hw and low and behold, there is a black box just above the grey outlet..... have no idea what it could be either. the shower is right above it but that is plumbed into the grey tank that is directly under the shower drain.
The mystery box does have a small hole in it so it can't hold any liquid.
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is online now   Reply With Quote
