Old 07-28-2014, 02:03 PM   #1
Does anyone know what this box is?
I have a hw276 the box is on the driver side above the grey water drain outlet.
ID:	59145   Click image for larger version
ID:	59146   Click image for larger version
kinma13 is offline   Reply With Quote
Old 07-28-2014, 02:22 PM   #2
dcheatwood's Avatar
Looks like a sunken battery box. Can you access the top of it thru a storage hole?
2018 Forester 3011 DS
Old 07-28-2014, 03:13 PM   #3
arff2108's Avatar
mystery box
A plastic box loosely mouted to the underside of cheap plywood doesn't seem sturdy enough for batteries. Especially with the bounce/vibration while traveling down the road.
Salem 27rkss
2005 Ram 1500
arff2108 is offline   Reply With Quote
Old 07-28-2014, 03:26 PM   #4
dcheatwood's Avatar
Looked like it might be sat down in the hole from above and hanging from a lip. If its mounted from the bottom I can only think its weatherproofing something. Hopefully someone will chime in with insight.
Old 07-28-2014, 03:48 PM   #5
Ford Idaho's Avatar
Does not look like it is attached real well (one screw in each corner?)..
What is right above it on the wall?
Old 07-28-2014, 04:06 PM   #6
Twisty's Avatar
...and what is the curly white thing?!!?
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 07-28-2014, 04:07 PM   #7
Not battery box. The batts on the tonque. Its right below the slide out so no access from in the trailer. Just wondering what it might be. Just seen it when I was trying a setup for the grey dump connection to the stinky slinky. A garden hose takes to long.
Old 07-28-2014, 04:08 PM   #8
Twisty thats the rubber cable for the cap on my grey dump outlet.
Old 07-28-2014, 04:19 PM   #9
Does the slide above have kitchen or any infrastructure? Or is it just furniture. I would guess it's a place for wires or hoses to hang slack when slide moves in or out. Beyond that, you got me.
WildSideFL is offline   Reply With Quote
Old 07-28-2014, 07:17 PM   #10
f5moab's Avatar
Maybe it is me, based on a a job I used to have, but looks like it would hold a few bricks.
f5moab is offline   Reply With Quote
Old 07-28-2014, 07:23 PM   #11
above the grey water drain, do you have an outside shower or perhaps a water filter or perhaps the electric water heater on the side of your TT? perhaps it is a cover for one of these items?
Rockwood Roo is working out better than I ever expected.
2012 Rockwood Roo 21ss
TV- 2015 Dodge Ram 1500 w/tow package
Camping fan is offline   Reply With Quote
Old 07-28-2014, 07:24 PM   #12
X2
2003 Dodge Ram 2500 5.9 Diesel
2014 Rockwood 2608WS
Big Paul is offline   Reply With Quote
Old 07-28-2014, 07:59 PM   #13
F5moab rofl.
Camping fun its a pup but yes has all that but all of that is at the front of the slide this box is behind the tire. Has me puzzled.
Old 07-28-2014, 08:05 PM   #14
vinmaker's Avatar
Not sure what that is. Strange.
But what about the plywood? Why is it not protected anymore? My Rockwood has a black mesh type covering over it. Promax I think it was called. Did they stop using it? is the plywood just exposed to the road water now? Will that not destroy it? I have never seen exposed plywood on the bottom of a camper before.
Confused.
Vin.
Old 07-28-2014, 08:05 PM   #15
Just remove it and have a look see
2018 Dodge 1500 4x4 5.7 HEMI
2013 Rockwood Ultra Light 8289WS
Night's Camped 2014 ( 37 ) 2015 ( 28 ) 2016 (46)
2017 ( 51 ) 2018 (54) 2019 (56) 2020 (4)
Merrickville Ontario
Manfred & Denise
freddy2 is offline   Reply With Quote
Old 07-28-2014, 08:10 PM   #16
Plain Old Member
Off topic a little, but our popup had bare wood underneath too. I undercoated it right after purchase.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 07-28-2014, 08:14 PM   #17
VinceU's Avatar
That looks like its protecting something, not supporting anything. Very light weight Vac injected plastic. The wood is OSB make with waterproof glue. Its normally covered to prevent abrasion from road debris. That black mat is not watertight. One of my pups in the 80's had similar construction, made by Coleman.
Old 07-28-2014, 08:23 PM   #18
asquared's Avatar
You mention it is located below the slide, could it be protecting or housing a slide out motor?
<a href=https://i62.tinypic.com/28rp645.jpg target=_blank>https://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 07-28-2014, 08:33 PM   #19
vinmaker's Avatar
It looks like it might have a hole in it as well? Wonder if it is a catch drain for any water that might get under the slide.
Vince. How do we know it is waterproof glue? Is it special RV wood sheets? This is scary. I too would like to undercoat mine but what about trapping moisture in? Wood and water is tricky.
Old 07-28-2014, 09:17 PM   #20
Fishhawk1650's Avatar
I'll don't recall seeing this box under my popup but will have to take a second look.
I'm intrigued by your grey tank fitting. Are you able to attach a 4" sewer hose bib to it?
I've been using a garden hose fitting that goes to the sewer hose and while it works, it's crazy slow. Short of redoing the plumbing, I've been trying to come up with ideas to either have a 4" connection to the grey tank or even better, join the two dump gates to a single hose connection.
Fishhawk1650 is offline   Reply With Quote
