Old 08-28-2011, 10:55 PM   #1
Does my 95 Rockwell XL 1076 have a water pump?
Ok so this may sound dumb, but how can I tell if there is an electric water pump on my pup? I bought a 1995 Rockwell XL 1076 a week ago. The seller told me it had a water pump but he had never used it. How can I verify this?
My power panel has a three position rocker switch that has converter, battery, and off as the setting. Is this the water pump control?
Thanks for the help.
Gotprops is offline   Reply With Quote
Old 08-28-2011, 11:35 PM   #2
Bill_C's Avatar
Can't answer your question, don't have that trailer type. However, there are no dumb questions, just stupid mistakes.
DRINK COFFEE--do stupid things faster and with more energy ! Rockwood 5th wheel, Signature Untralite, 8244S
Tow Vehicle: Ram 3500 6.4 litre Hemi.
Bill_C is offline   Reply With Quote
Old 08-29-2011, 01:47 AM   #3
look by your water tank and see if there is a pump there then if there is start looking for another switch it should just be an off and on maybe even might be a tank level indicator with a off and on switch /Does your sink have a regular facuet or is it a pump type ? The switch you mentioned may be the water heater or a furance Good luck on your search let us know if you find it
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 08-29-2011, 05:28 AM   #4
I recall the switch low and by the enter/exit door on our Flagstaff, but it's been a while.
Kirk, KN1B
2013 Cardinal 3800FL
2009 GMC 3500HD CC LB SRW
kbrown1075 is offline   Reply With Quote
Old 08-29-2011, 06:42 AM   #5
KyDan's Avatar
If it's got a manual pump type faucet it probably has no 12v pump.
If it has a water heater it will have a water pump.
Old 08-29-2011, 07:22 AM   #6
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
This will help some, at least for the switch. Even though your camper is newer, I doubt you have a 12 volt water pump. If you do, there should be a fuse for it, probably in the converter.
dimurrrw is offline   Reply With Quote
