Old 04-23-2015, 09:12 PM   #1
Dome lights
So we're set up on our first night in our camper and the interior lights don't work. The refrig works, pump works, all 120 v outlets work. I checked the fuse and it is OK. Any thoughts as to what the problem might be?
kraftengr is online now   Reply With Quote
Old 04-23-2015, 09:22 PM   #2
grumpyer's Avatar
switch at lites turned on?
grumpyer is offline   Reply With Quote
Old 04-23-2015, 09:58 PM   #3
Yes. We also have a fan/light accessory that plugs into the light fixture that doesn't work!
Old 04-23-2015, 10:11 PM   #4
f5moab's Avatar
Did you check the safety switch where the sink fold up over? One of those switches cuts off power to the roof light to prevent the lights from being left on when the top is folder down. If left on, they will burn the side fabric.
f5moab is offline   Reply With Quote
Old 04-24-2015, 08:23 AM   #5
ordinaryguy's Avatar
Dome lights
Oh, I went through that- tore out the breaker panel, traced wiring (no ceiling fan or lights), saw some mystery wires leading back to a.....switch under the galley, which had not lowered the last 1/4"!!! Learned a lot about the wiring, though. I didn't like all the ground wires in a giant wire nut with 10 feet of tape, put terminals on all of them and screwed to a buss strip.
2014 Rockwood Freedom 1950
2014 Subaru Outback 6cyl
ordinaryguy is offline   Reply With Quote
Old 04-24-2015, 08:37 AM   #6
That was it! Wires pulled loose from the safety switch! Thanks
light
