Old 08-21-2016, 10:04 PM   #1
Dometic Refrigerator Issue
On our last trip out in our 2014 Rockwood 2514G, the Dometic refrigerator quit working on 110v. We had been out for a couple of days and everything was cold, the third day it was warm. We switched over to propane, and it started cooling again.
I verified there is power to the 110v outlet the fridge is plugged into, and that the switches were all in the correct settings. I turned the temp control knob back and forth to try and "clean" the connections, and it's still not working.
Wondering if anyone else has had this same problem, and if anyone has any ideas. I'm hoping I'm missing something stupid, but I have a feeling this will be expensive...
cousin_eddie is offline   Reply With Quote
Old 08-22-2016, 07:18 AM   #2
f5moab's Avatar
From what I have heard, if it works on one fuel you have hope. The ammonia has not leaked out. Also, if it works on one fuel it is most likely not the thermostat. This is what I was told on the phone by a repair person in another state.
Have you tried operation on DC?
But you just MIGHT be still on warranty. I thought mine came with a two year warranty (on some parts not sure what).
f5moab is online now   Reply With Quote
Old 08-22-2016, 07:27 AM   #3
dcheatwood's Avatar
Mine went out in the spring and I found a blown glass fuse in the panel behind it. Had to remove the cover on the mother board, lower left in the rear, and it was a vertical fuse. I'll try to get a picture. good luck.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 08-22-2016, 07:46 AM   #4
dcheatwood's Avatar
My fuse looked good but when checked for continuity, it was bad. Hope this helps.
Old 08-22-2016, 07:49 AM   #5
SeaDog's Avatar
You may also want to do a continuity check of the heating element it may have burned out.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 08-22-2016, 08:08 AM   #6
Similar thing happened with us except that the 120v AC works now. We own a 2015 2514g popup. Love it! This summer used it for three trips. On our second trip the fridge stopped working on 120v AC so I switched to propane and it worked fine. Drove home with it on12v DC and it worked fine. Plugged it in at home and it worked fine. Our third trip used it on 120v AC and it worked fine. Don't know what it was that made it stop working. The campsite we were on was very level. Fuses were all good. Socket it's plugged into and GFI all good. It's one of those things that I'm not obsessing about because it works fine on propane. Many people use fridge on propane anyways. But it does sit in the back of my mind wondering "why".
Rexford is offline   Reply With Quote
Old 08-22-2016, 08:22 AM   #7
Dcheatwood - Thanks for the heads up! I was hoping for something like this as a possibility, I will check it out when I get home from work.
Rexford - I had thought ours did that as well, meaning I thought it quit working on one trip but it was right before we left, and it worked when we got home so I never questioned it. This time it went out while we were camping, and it didn't come back when we got home.
The unit does work on 12v, but the inverter doesn't like to run it that long on 12v :-)
Old 08-22-2016, 08:27 AM   #8
Hmmmm. That concerns me now. Maybe I shouldn't ignore it then. We just bought the popup in March. I should check on my warranty for it then.
Old 08-22-2016, 08:27 AM   #9
f5moab's Avatar
Exactly where is that circuit board located? I could not find one on my 2193. The 2193 is a very basic small 3-way fridge located in most popups. Also looked at the parts list for the fridge and no circuit board is listed. I'm going to throw out a SWAG that this small very basic fridge does not have one; or it just might not be a serviceable unit.
Old 08-22-2016, 08:34 AM   #10
f5moab's Avatar
Not sure if it will run on DC when connected to AC power. Not sure the WFCO converter would like it. So I used my two deep cycles mounted to the trailer and a battery charger to see if it works on DC.
dometic, refrigerator
