Door problems
Hi all,
First post here. I just picked up my 2017 HW277 and so far am loving it. I can't seem to make the door set into the frame right though. When you set the door down into the frame, the top aluminum panel that sticks above the door is way past where the retainers are (the retainers are mounted where they would be on top of the flat aluminum panel). My question is this: Is that even the correct placement for the top retainers? There doesn't seem to be any way that it will fit where they are currently mounted. After watching the DVD that came with the pup, the retainers that are shown (albeit an older model) are on the side of the aluminum panel. Any guidance appreciated.
2017 Rockwood HW277
2013 Ford F150 Crew Cab FX4
