Old 06-23-2016, 10:05 AM   #1
Double towing with HW296
Hi. Has anyone ever towed a small lightweight boat on a trailer behind one of these. I am assuming you could get Uhaul or the like to mount a receiver hitch to the frame. I would only be towing less than 750 lbs. and yes I know it's only legal in some states.
BankerCamper is offline   Reply With Quote
Old 06-23-2016, 10:46 AM   #2
There are numerous threads here about the same question, some with pictures as to what happens.
I suggest you use the search and see for yourself.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2017- 16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 06-23-2016, 10:53 AM   #3
I used to tow a boat and trailer behind my hybrid for years. The trailer dry weight was around 3000lb so about 4000lb running down the road. Pulled with a full size truck, half and 3/4 ton. Never had an issue, the boat weighed about 1500lb I would guess with the trailer. You cant back it up so make sure you can pull in wherever you go. There is a website that has the states and dual trailer regs. Like everything else, make sure you have a good setup on your hitch, anti sway etc. and it is not that bad. If you are pulling close to your weight rating with both trailers, bad idea.
Steve
Golden CO
2016 Grey Wolf 26RR Limited
92 GMC K2500 454
2006 Honda Rubicon ATV
zuterbru is offline   Reply With Quote
towing
