Old 06-25-2014, 07:50 PM   #1
loobdyloo5's Avatar
Drain hose from 1 1/2 inch to a 3 inch
We need help. We can't find the right fitting to switch our popup drain out, 1 1/2 to the standard 3 inch. We have looked and looked. Has anyone else had to do this?
loobdyloo5 is offline   Reply With Quote
Old 06-25-2014, 07:59 PM   #2
Who Dares, Wins
doc73's Avatar
Never did do it when we had our PU. I ended up getting the 1.5" Sump pump hose and with duck tape and some luck made it fit a sewer 3" 90 for hooking to the sewer connection (not a tight fit just stuck into the adapter.
I had made a PVC 45 that threaded onto the PU connection once so I do not see why you could not adapt it up to a 3" PVC stub and then use a fernco to a bayonet adapter for the standard sewer connection.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 06-25-2014, 08:03 PM   #3
loobdyloo5's Avatar
Ok I'm going to try and find a picture of a fernco piece. Lost on this one. Thanks
Old 06-25-2014, 08:08 PM   #4
Who Dares, Wins
doc73's Avatar
My old set up:
Can't believe I still had these pics...
One of these type things:
"Valterra Ez Coupler Bayonet Ftg F02-3108" | Bizrate
Fernco:
2015 ChevyHD D-Max
Old 06-25-2014, 08:09 PM   #5
Who Dares, Wins
doc73's Avatar
The bayonet fitting can be had from Wally World. the other parts at a Lowes or HD
2015 ChevyHD D-Max
Old 06-25-2014, 08:12 PM   #6
loobdyloo5's Avatar
Lol, thank u. I'm studying your picture!
Old 06-25-2014, 08:15 PM   #7
Who Dares, Wins
doc73's Avatar
Pics are from 07 or 08... But any ways the black tube was bought at HD if you wnet my McGyverism route
2015 ChevyHD D-Max
Old 06-25-2014, 08:45 PM   #8
Maybe this will help you at one end or the other:
US Adventure RV. Eccentric Tank Reducer, 3" x 1-1/2"
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 06-25-2014, 08:58 PM   #9
Who Dares, Wins
doc73's Avatar
That could be used possibly. Might cut down the use of adaptors. Could be used to adapt the 1.5 to 3" quicker.
Sent from my SAMSUNG-SGH-I747 using Forest River Forums mobile app
2015 ChevyHD D-Max
Old 06-25-2014, 09:59 PM   #10
loobdyloo
a
are you talking the grey tank drain?
I also have a hw276 with the same. i found this post from someone else and it looks to me that it will work ill be doing this over the weekend and ill post pics of it
Here's a easy fix for the grey tank- get a Valterra T01-0091VP
then a camco 39533. connect the 2 with a small hose (should be garden hose size i believe. then just connect the rinse cap to a Camco 39812. then connect your black sewer hose and y pipe to the drian. hope this works.
ignhavefun:
kinma13 is offline   Reply With Quote
drain
