Old 04-09-2016, 09:14 PM   #11
Originally Posted by youroo View Post
Really! If the Dealer says that just Post the Dealers Name on Here and they will "Change Their Mind"! Youroo!!
Well I think that pretty much wraps it up.
Thanks for the input guys!
Will get it into the shop and post a reply as a follow up!
2016 HW27KS
dompeticca is offline   Reply With Quote
Old 04-11-2016, 06:03 PM   #12
Called the dealer, they say they are booked through the next 4 weeks! Apparently my existing appointment on May 4th is the best they could do.
At this point I'm not getting the warm and fuzzies about my 17k investment
If they are that busy, hopefully it's not all warranty repair work!
If they're not really busy, but just preferring to do paid vs unpaid warranty work, then should I just look for another dealer instead?
2016 HW27KS
Old 04-11-2016, 07:22 PM   #13
caper's Avatar
It is spring and most dealer are busy getting units ready for the camping season.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
caper is online now   Reply With Quote
Old 04-11-2016, 07:32 PM   #14
Originally Posted by caper View Post
You could install this for a quick fix.
Don't fiddle with it before you get it back to the dealer. Also, pm the guy who said his unit and three others had the same problem as yours to bolster your case with your dealer and a claim under warranty. Just sayin'
Old 04-11-2016, 07:43 PM   #15
Call Rodger Beiler "Rockwood hardside P/U Service" 574-642-8931! E Mail rbeiler@ forestriverinc.com! Talk to him about using a "Independent repair person/shop" you will still need to get a Service# and OK but try that Route! Youroo!!
Old 04-11-2016, 11:07 PM   #16
caper's Avatar
I just suggested using the rubber joint so you could use the unit till it was repaired. The part cost less then $10 and if you are at a campground would allow pipe to be repaired for a short term. If you have to wait 4 to 6 week to get your unit into the RV shop it will allow you to use the trailer while waiting. I am not recommending this as a permanent fix.
Terry and Janet
2007 Ford F150
Old 04-12-2016, 12:20 AM   #17
Just a member
kandl's Avatar
Originally Posted by dompeticca View Post
Later on I was running the water and the wife said it was leaking... went outside and found this crack...
That's way past the point of being referred to as a crack. The pic is not clear but it appears to look as if someone sawed through the pipe.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 04-12-2016, 04:21 AM   #18
I'll second that! Sawzall looking! Youroo!!
drain
