Old 04-09-2016, 07:31 PM   #1
Drain line Cracked!
Was putting up the camper top and heard a loud crack!
Later on I was running the water and the wife said it was leaking... went outside and found this crack...
How easy it this to fix? I have a one year check up with the dealer on May 4th, should I have them to a look at then? Is a warranty issue perhaps? Looking at the pipes they seem to be about a 1/2 to 3/4 inch out of alignment.
dompeticca is offline   Reply With Quote
Old 04-09-2016, 07:51 PM   #2
Is that the gray line? What year is the camper?
2016 HW296
2016 Ford F-150
tigger68 is offline   Reply With Quote
Old 04-09-2016, 07:57 PM   #3
Ford Idaho's Avatar
Can you tell if the tank moved and if so which way.
Also check for broken braces for the tank.
Old 04-09-2016, 08:16 PM   #4
This is a 2016 HW27KS. I bought it last July/August or so. I believe this PVC tube feeds into the gray water line, I could be wrong though, haven't looked/mapped out the system under neath yet. I thought it may be the pipe coming from the reserve water tank system since it appears to be a holding tank below where the fill up is on the passenger side of the camper.
I can't tell if the tank has been bent or moved, will look tomorrow when it's light out to see if there are any braces that appear to have come loose.
Old 04-09-2016, 08:34 PM   #5
Take back to the Dealer NOW! You have a Big issue,you don't need a Checkup you need a Major repair! Youroo!!
Old 04-09-2016, 08:40 PM   #6
That's funny. We have a 2016 HW296 and we had the same issue. Take it back it's a defect my dealer said they had seen 3 before we took it in last summer.
2016 HW296
2016 Ford F-150
Old 04-09-2016, 08:51 PM   #7
caper's Avatar
You could install this for a quick fix.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 04-09-2016, 08:53 PM   #8
Appreciate the advice that this is a warranty repair. Can you guys elaborate on what the problem is exactly? I think my dealer is all right, but what if they try to say it's my problem?
2016 HW27KS
Old 04-09-2016, 09:07 PM   #9
Really! If the Dealer says that just Post the Dealers Name on Here and they will "Change Their Mind"! Youroo!!
Old 04-09-2016, 09:12 PM   #10
W5CI's Avatar
I hope it's no Camping World
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2019 Days Camping 25
2020 Days Camping 7
W5CI is offline   Reply With Quote
Old 04-09-2016, 09:14 PM   #11
Well I think that pretty much wraps it up.
Thanks for the input guys!
Will get it into the shop and post a reply as a follow up!
2016 HW27KS
Old 04-11-2016, 06:03 PM   #12
Called the dealer, they say they are booked through the next 4 weeks! Apparently my existing appointment on May 4th is the best they could do.
At this point I'm not getting the warm and fuzzies about my 17k investment
If they are that busy, hopefully it's not all warranty repair work!
If they're not really busy, but just preferring to do paid vs unpaid warranty work, then should I just look for another dealer instead?
2016 HW27KS
Old 04-11-2016, 07:22 PM   #13
caper's Avatar
It is spring and most dealer are busy getting units ready for the camping season.
Terry and Janet
2007 Ford F150
Old 04-11-2016, 07:32 PM   #14
Don't fiddle with it before you get it back to the dealer. Also, pm the guy who said his unit and three others had the same problem as yours to bolster your case with your dealer and a claim under warranty. Just sayin'
Old 04-11-2016, 07:43 PM   #15
Call Rodger Beiler "Rockwood hardside P/U Service" 574-642-8931! E Mail rbeiler@ forestriverinc.com! Talk to him about using a "Independent repair person/shop" you will still need to get a Service# and OK but try that Route! Youroo!!
Old 04-11-2016, 11:07 PM   #16
caper's Avatar
I just suggested using the rubber joint so you could use the unit till it was repaired. The part cost less then $10 and if you are at a campground would allow pipe to be repaired for a short term. If you have to wait 4 to 6 week to get your unit into the RV shop it will allow you to use the trailer while waiting. I am not recommending this as a permanent fix.
Terry and Janet
2007 Ford F150
Old 04-12-2016, 12:20 AM   #17
Just a member
kandl's Avatar
That's way past the point of being referred to as a crack. The pic is not clear but it appears to look as if someone sawed through the pipe.
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
kandl is offline   Reply With Quote
Old 04-12-2016, 04:21 AM   #18
I'll second that! Sawzall looking! Youroo!!
drain
