Old 04-09-2016, 07:31 PM   #1
Drain line Cracked!
Was putting up the camper top and heard a loud crack!
Later on I was running the water and the wife said it was leaking... went outside and found this crack...
How easy it this to fix? I have a one year check up with the dealer on May 4th, should I have them to a look at then? Is a warranty issue perhaps? Looking at the pipes they seem to be about a 1/2 to 3/4 inch out of alignment.
dompeticca is offline   Reply With Quote
Old 04-09-2016, 07:51 PM   #2
Is that the gray line? What year is the camper?
2016 HW296
2007 Jeep Grand Cherokee
Nights Camped
2015 -- 4
tigger68 is offline   Reply With Quote
Old 04-09-2016, 07:57 PM   #3
Ford Idaho's Avatar
Can you tell if the tank moved and if so which way.
Also check for broken braces for the tank.
Old 04-09-2016, 08:16 PM   #4
This is a 2016 HW27KS. I bought it last July/August or so. I believe this PVC tube feeds into the gray water line, I could be wrong though, haven't looked/mapped out the system under neath yet. I thought it may be the pipe coming from the reserve water tank system since it appears to be a holding tank below where the fill up is on the passenger side of the camper.
I can't tell if the tank has been bent or moved, will look tomorrow when it's light out to see if there are any braces that appear to have come loose.
Old 04-09-2016, 08:34 PM   #5
Take back to the Dealer NOW! You have a Big issue,you don't need a Checkup you need a Major repair! Youroo!!
Old 04-09-2016, 08:40 PM   #6
That's funny. We have a 2016 HW296 and we had the same issue. Take it back it's a defect my dealer said they had seen 3 before we took it in last summer.
2016 HW296
Nights Camped
2015 -- 4
Old 04-09-2016, 08:51 PM   #7
caper's Avatar
You could install this for a quick fix.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 04-09-2016, 08:53 PM   #8
Appreciate the advice that this is a warranty repair. Can you guys elaborate on what the problem is exactly? I think my dealer is all right, but what if they try to say it's my problem?
2016 HW27KS
Old 04-09-2016, 09:07 PM   #9
Really! If the Dealer says that just Post the Dealers Name on Here and they will "Change Their Mind"! Youroo!!
Old 04-09-2016, 09:12 PM   #10
W5CI's Avatar
I hope it's no Camping World
Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2017 Days Camping 77
2018 Days Camping 3
W5CI is online now   Reply With Quote
drain
