Old 07-15-2018, 06:14 PM   #1
Draining hot water tank/ rockwood HW 277
I have read a little about this and think I know the answer but would like to confirm this. I have not been able to find a separate drain port for our trailers hot water tank. So thinking the only way to drain is to remove the element to drain? Is this correct or is there another way I am missing?
Qball is offline   Reply With Quote
Old 07-15-2018, 06:20 PM   #2
Flybob's Avatar
From your question, it appears you have a suburban WH. To drain a Suburban WH, you need to remove the anode rod. The large hex head in the center bottom behind burner tube. Be sure to ad a wrap or two of teflon tape when installing. Note it is a tapered thread and does not seat all the way in as a bolt would.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-15-2018, 06:23 PM   #3
That is what I was thinking but wanted to make sure there was not another way. Thank you!
Old 07-15-2018, 06:25 PM   #4
Mr. Dan's Avatar
Keep in mind that the element and the anode rod are not the same thing.
Old 07-21-2018, 02:10 AM   #5
Nope all you have to do to drain the hot water tank is open ur low drain points.
kinma13 is offline   Reply With Quote
Old 07-21-2018, 02:17 AM   #6
Just a member
kandl's Avatar
Nooooo... plse don't do that! You'll fill the plumbing with all manner of scale and crud from the HWT and it can be a PITA to clean out.
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
kandl is offline   Reply With Quote
Old 07-21-2018, 05:00 AM   #7
I agree with this advise,with a little addition,"Not all RVs are plumbed the Same,draining through your LP Drains MIGHT draw White CRUD downstream"! Using the LPD as a WH drain can be a "Delayed Reaction Problem Downstream"! Youroo!!
Old 07-21-2018, 10:32 AM   #8
I clean my tank every time after a trip. Didn't fully read op sorry.
drain, hot water, rockwood, tank, water, water tank
