Old 03-22-2016, 02:49 PM   #1
Dumb newby questions
I have 2016 gmc acadia that came with a factory installed hitch and towing package, is it capable of towing a Flagstaff HW29SC, if so would you do even try to pull that kind of tent camper?
jdftwrth98 is offline   Reply With Quote
Old 03-22-2016, 02:54 PM   #2
Moderators' Assistant
bikendan's Avatar
you need to post the car's specs.
engine size, payload capacity, towing capacity to start.
that trailer has a GVWR of 5000lbs., too pretty heavy for any minivan made, except the Astro.
if the acadia is rear wheel drive, then the rear end ratio.
if i remember, the Acadia has only a 3500lbs. towing capacity, even with the towing package.
but i could be wrong. it might have a 5000lbs towing capacity.
but even if it does, you'd be close to exceeding that amount when it's loaded for camping and you have passengers and cargo in the vehicle.
Dan-Retired Firefighter/EMT
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 03-22-2016, 02:56 PM   #3
Head Rambler
The tow rating on your Acadia is 5,000 lbs. and the GVWR of the 29SC is 5,000 lbs., so technically you can tow it. It's all going to depend on how you load the RV and the TV as to whether it's a good fit.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 03-22-2016, 02:57 PM   #4
RollingDownTheHighway's Avatar
my wife has the same SUV, you can tow #5200.
The only thing different between AWD and FWD is the actual weight of the SUV.
2016 Acadia Trims: Mid-Size SUV Options - GMC
2013 Prime Time Tracer 3200BHT
2016 GMC Crew Cab Duramax All Terrain
Ribs in the smoker and Whiskey in hand
RollingDownTheHighway is offline   Reply With Quote
Old 03-22-2016, 03:12 PM   #5
Well Duh!
Like I said in my initial post, dumb newby question.
Its a front wheel drive 6cyl with 7pin connector and a 2 inch hitch opening.
max tow capacity 5200 lbs
max hp / torque 288 @ 6300 / 270 @ 3400
MAXIMUM tongue weight rating of 600 lbs with or without a WDH
We live in Texas so its pretty flat.
Old 03-22-2016, 03:18 PM   #6
2014 Solaire 147X
RamsFan1's Avatar
The Acadia has the same 5200# towing capability as our Traverse.
Get a weight distribution hitch and you should be fine.
2011 Chevy Traverse
2014 Solaire 147X
RamsFan1 is offline   Reply With Quote
Old 03-23-2016, 04:03 PM   #7
With a non-turbo 6 cylinder engine, and a High Wall PUP, and towing 5,000lbs, you will probably struggle with keeping up to Texas speed limits. Wind resistance is more important than weight in determining what/how well you can tow in the lighter RVs and 6 cylinder tow vehicles.
I tow a normal height Rockwood A122 (A-frame) that weighs right around 2800lbs in camping trim (+120lbs for full water tank). Tow vehicle is a Hyundai Entourage minivan that's rated for 3500lbs in US and 5000lbs in Europe. TV has a 3.5L 250HP V6 with over 250 ft-lbs torque and a 5 speed xmsn with a large xmsn fluid cooler.
Because I live in Colorado and camp in Nebraska, Colorado, Texas, Utah, Wyoming, California, we have to contend with serious mountains. I would not want to tow anything bigger on the grades or in the winds we encounter. The wind has caused my gas mileage to dip from 19 (normal towing) to 13mpg (30MPH headwinds) at 65 MPH. Speed and acceleration is OK at my weight and windage, I can maintain highway speeds up a 6% grade in 3rd gear. I can pass slower RVs on the upgrades when a passing lane is present.
Because of the 13 in ST tires, I try to refrain from going over 65MPH on the interstate - this may not be practical in Texas. If I can find some tires rated for higher speeds, I will replace mine.
A WDH was essential to giving the minivan a near-normal ride while towing the A-frame.
Previously, I had a 1993 Ford Explorer (175 HP 6 cylinder, 4 speed xmsn) that slowed way down going up the mountain grades towing a 3200lb PUP. Going to the Eisenhower tunnel (11,000ft on I70), I was down in 1st gear at 20MPH.
These are just my experiences, yours may differ. I suggest you be prepared to want a more substantial TV, or go with a smaller camper (we chose the latter so it would store in our garage).
Fred W
2014 Rockwood A122 A-frame
2008 Hyundai Entourage minivan with Equalizer WDH/anti-sway
1993 Ford Explorer
2000 Coleman Westlake PUP (no WDH, not a comfortable tow)
Old 03-23-2016, 04:13 PM   #8
Thanks for your comments, that pretty much matches the conclusions that I had come to.
So, its time to rethink my ideas and find a better solution, (i really do dislike the idea of buying another tow vehicle but if thats what its gonna take then so be it).
