Old 06-19-2014, 11:03 AM   #1
Electrical diagram 1904 Rockwood 2012
Hi
I have a Premier 1904 year 2012 and I would like to install a pole on the ceiling of the pop up and I am looking for the routing of the electrical wires inside the top to avoid any damage, is there a diagram or drawing that could help me?
I want to install it over the table or the bench next to the burner
THanks
1904Camper2012 is offline   Reply With Quote
Old 06-19-2014, 11:05 AM   #2
TURBS's Avatar
No such diagram exists.
Old 06-19-2014, 11:14 AM   #3
so is ther a way to install pop rivets and make sure I won't cut or damage any wire?
Old 06-19-2014, 11:27 AM   #4
Kaadk's Avatar
Unfortunately I believe each unit is wired by hand, and two identical units might not have their wiring done the same way.
So, I can't think of anything that will be 100% foolproof. You might be able to use one of those wire detectors, but I believe the can only detect live wires, you could still possible miss finding any wires that aren't producing an EMF.
In my TT, I just try to follow the same common sense I do in my house. Near plugs, lights, etc. you can expect to find wires. Aside from that, look to see where those wires would logically go. For instance, in a pop up, if all the wires are in one corner to run down a single support pole, then the far opposite corner most like won't contain any wires from that light in the middle of the roof.
Old 06-19-2014, 12:50 PM   #5
thanks Kaadk. Common sense is really the way to use, so I have decided to use velcro instead, it'll work and will be safe. Thanks again for your feed back.
Old 06-20-2014, 07:40 PM   #6
God Mode
I have a 2013 1904 and if you have trouble finding anything, search you'll find the Flagstaff 620ST and the 206ST are basically the same.
maxters is offline   Reply With Quote
Old 06-20-2014, 09:05 PM   #7
thanks, finally, I used velcro instead.
Old 06-21-2014, 04:02 AM   #8
Incheon, S. Korea
BigBaron's Avatar
FWIW - none of the FR popup trailers have schematics, or they don't publish them. I've asked.
Me, Julie, Lil' Barry, Faith, and OSD Fang
2012 Coachmen Clipper 126 - Don't even have a TV anymore.
I don't know when we'll be able to go camping again...
BigBaron is offline   Reply With Quote
Old 06-22-2014, 08:06 AM   #9
thanks. I will use velcro instead of screws. strong enough
2012, electric, electrical, rockwood
