Old 08-15-2016, 07:29 AM   #1
Cowboy6201's Avatar
Emergency fix in Maine
When I was getting my 296 put down and leaving for Maine the next day, I discovered the wire the switch cutting power to the interior lights fell off.
I had no time to fix it.
So I had no choice but to fix it in Maine before I put the roof up.
All is good now, just gotta get a new screw they're brass and it stripped while trying to get it out.
Cowboy6201 is offline   Reply With Quote
Old 08-15-2016, 07:35 AM   #2
Head Rambler
Thanks for posting this. The picture helps a lot. I'm sure it'll help someone to see what that switch looks like.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 08-15-2016, 11:32 AM   #3
Cowboy6201's Avatar
No problem, it easier if the roof is only raised up just enough to get in there, and better if you access it from the front and not the side.
Yo take it out it's 2 screws that hold the switch in, and 2 more attaching the connectors on that the wires are crimp in to. It's that easy.
But watch the screws to the wire connectors they're brass and strip easy, they're combo Philips and straight screw driver, u can either one.
The switch is marked on either side + & - note which wire goes where.
