Originally Posted by Bama Rambler
Thanks for posting this. The picture helps a lot. I'm sure it'll help someone to see what that switch looks like.
No problem, it easier if the roof is only raised up just enough to get in there, and better if you access it from the front and not the side.
Yo take it out it's 2 screws that hold the switch in, and 2 more attaching the connectors on that the wires are crimp in to. It's that easy.
But watch the screws to the wire connectors they're brass and strip easy, they're combo Philips and straight screw driver, u can either one.
The switch is marked on either side + & - note which wire goes where.
