Old 05-17-2011, 07:12 AM   #31
Herk7769's Avatar
I normally carry just the 25 foot extension cord, but I camp at 3 locations where I need much longer runs (2 friend's farms and a FAMCAMP spot we love at Quantico Marine Base in VA). I made up a 30 amp 100 foot cord for those trips. Lowes and Home Depot carries the rubberized 30 amp wire and I ordered the yellow "ends with handles" online. You must be careful with power usage, with the Franks autotransformer at the camper to keep the voltage at 110-120, you can pull more amps from the pedestal than the breaker there can handle if you run the AC at the same time as any other high draw item.
HAM CALLSIGN - KC3FFW
Old 05-17-2011, 07:38 AM   #32
Triguy's Avatar
Originally Posted by KyDan View Post
Just go to Amazon.com and put in
30 amp RV extension cord.
This is the top hit-
Amazon.com: Conntek 14368 RV 30 Amp 25-Foot 10/3 Brilliant Yellow Extension Cord Straight Blade: Patio, Lawn & Garden
It's 25 feet long, $40 including shipping.
I only have one but if I wanted 50 feet I'd still go with
2 25s because it's gonna be rare to need a 50 on top
of the 25 that comes with most RVs. (I haven't needed
50 extra yet but have used the 25 several times.)
two 25's - that's a good idea.
So, i see that the cord linked to has 30amp plugs.
The reason I was asking is that I have a 10/3 but with the 15amp plug. Are there any loss of voltage or problems that could occur from using a 15A/30A adapter?
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 05-17-2011, 07:51 AM   #33
Herk7769's Avatar
You are going to lose voltage due to resistance at every brass to brass connection. You will have a connection at the camper wall; the end of the shore cord, the end of the first 25, and the end of the second 25 at the pedestal in addition to voltage loss in the 75 foot run of wire.
Hooking and unhooking while under load burns the tips and blades and increases the voltage drop so always kill the breaker before connecting to the pedestal.
If you monitor your AC you will find the more cord you use the greater the need for an autotransformer.
Old 05-17-2011, 09:42 AM   #34
Triguy's Avatar
Hmm. Got it (I think).
BTW - I ran across this table the other day looking at battery chargers.
Scott
2012 Shamrock 233S
Old 05-17-2011, 09:45 AM   #35
(Kim)
Labzy's Avatar
I think I will just end up having my dad make me a custom length cord.
This way, I am guaranteed good quality.
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
Labzy is offline   Reply With Quote
Old 05-17-2011, 06:53 PM   #36
sherdep's Avatar
You are gonna let him make it so you can save on the price of the cord and ends - If he makes it to be a really good quality cord you wont be able to carry it then
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 05-18-2011, 05:28 AM   #37
Originally Posted by kbrown1075 View Post
Bought one from Wally World. Plug connections burned due to poor contacts on the female plug of extension. Cut ends off and replced plugs, now use for a generator plug. Paid a little more and got one from camping world. The cord is important, safety isn't worth a couple bucks. Get the good one.
Just to clarify: the cord I purchased from Wal-Mart was a 30 AMP RV Extension cord. The problem was the connections in the female plug on the cord. They are not made of heavy enough material to provide enough spring tension on the blades of the male plug. The poor connection causes an increase in amperage over the small/ weak area of contact, increasing heat, hence burning the plug. I never "Hot Plug" my connections. I always make sure the breaker is off. Have burned male plug blades at CGs due to loose/ worn plugs. I have cut off the molded plg from my main cord and use a Camco plug. I keep a spare in the TT. If I burn a plug now, I just replace it before the next trip. Don't go and buy the cheapest extension you can find, you will probably regret it. I bought the cheap one, then ended up buying the better one (from CW) a few months later. Just my 2 cents.
Kirk, KN1B
2013 Cardinal 3800FL
2009 GMC 3500HD CC LB SRW
kbrown1075 is offline   Reply With Quote
Old 05-18-2011, 11:00 AM   #38
(Kim)
Labzy's Avatar
I'm more concerned with the QUALITY...and.....this way, I can get a custom length, of let's say, 78' .
I also thought (now correct me if I'm wrong), that using multiple extension cords (3) is not a good thing.
And yes.....somehow we are back to the fact that I probably won't be able to carry it, but could probably roll it out
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
Old 05-18-2011, 12:05 PM   #39
DF5.4's Avatar
I was just at WalMart today. 30' 30A 10Gauge RV extension cord $41
Doug
2011 Prime Time Tracer 3000BHS
2007 Ford Expedition
Reese Dual Cam HP Hitch
Nights Camped 2015-5 in TT
DF5.4 is offline   Reply With Quote
Old 05-18-2011, 01:53 PM   #40
Herk7769's Avatar
I keep my 100 foot cord in a square milk crate. I fished about 3 feet of one end through a side bottom hole before I attached the female socket and then coiled the remainder inside the milk crate and attached the plug to the long end. That way what I don't need stays in the crate when I use it. The short end is tucked down the center of the coil when I put it away.
