Exterior Door Set Up Rockwood 2318G door doesnt fit
Hi All, The door does not fit correctly, I cant get the 2 top interior frame latches in the two holes on the top of the interior door frame.The guide wire when I lift the roof is not taunt, not sure if the lift wench needs slight adjustment to lift the roof a 1/4 inch higher, but I did notice is was not taunt b 4 ac install. Is it because I had a 15kbtu ac installed and. weight is to much? Can I push up on the roof to get the door to fit from the inside during setup? I tried to a little but it was heavy and I didnt want to break the roof. The dealership was able to get the latches into the two corresponding interior frame holes b 4 the ac install, but it was very hard to unlatch during take down. How taunt is the lift guide wire/rope suppose to be? I tried to setup the door with both the bed slides not pulled out completely but it made no difference.
