Old 04-30-2015, 08:32 AM   #1
Filter question
I have a 2015 rockwood hw276 with an in line water filter. I need to replace the fittings on the stock filter housing. I think the filter is cci 5 ca which is 5" and the lines are pex. I think the fittings are 1/2 but don't know if that's the size of the threaded or the outer nuts area. Pups not here right now 2 check.
kinma13 is offline   Reply With Quote
Old 04-30-2015, 08:44 AM   #2
Are you wanting to remove the filter and replace with regular plumbing? If so, we just did that and used a 6-inch long 1/2-inch pvc coupling. Just a couple dollars at Ace.
2004 Chevy Silverado 1500 Z71 4x4
2015 Flagstaff 205 Folding Camper
sewserious is offline   Reply With Quote
Old 04-30-2015, 09:19 AM   #3
Sewserious. Kinda but I don't want to cut or change any stock plumbing that way it can be put back if I ever sell
Old 04-30-2015, 09:47 AM   #4
No ned to cut anything. Our plumbing was attached to the filter housing with 1/2-inch female fittings. We took the filter housing and bracket out and use the male pvc coupler to join the 2 pieces of plumbing from each side of the filter together. Filter housing could be put back in by removing coupling, putting bracket back, hanging housing on bracket, and reattaching plumbing. If you do use a coupling, be sure to use some teflon tape. I should add that these were screw-in fittings,made it all really simple.
Old 04-30-2015, 10:52 AM   #5
Cool that's what I was thinking. When I get the pup back I'll be doing that. Thank you.
Old 04-30-2015, 02:13 PM   #6
vinmaker's Avatar
Kinma. I am not sure you can do what you want to do without cutting.
On my unit the PEX is clamped to the fittings with a metal band type clamp. It is not a water pipe clamp that you can just unscrew. I think at a minimum you will need to cut the PEX clamp off on both sides of the filter. Not sure if you can just cut the clamp of if you will need to cut the pip next to the clamp. Then you would just connect the two ends with fresh pipe.
I too am looking to do this MOD. Let me know how you make out and please post some pics. We love pics.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 04-30-2015, 02:29 PM   #7
Might add we have FS 205. The pex was attached to the brass screw-on fittings with bands and not diectly to the filter housing itself.
Old 04-30-2015, 03:35 PM   #8
Will do vin. I'll be doing it right after I de winterize it and b4 I sanitize. Hope it's pretty easy. Last I looked it seamed easy but don't remember
Old 05-01-2015, 07:22 PM   #9
GalsofEscape's Avatar
I removed the filter completely as well. Lowe's has a short flexpipe with connectors already on it. I took the filter housing with me and had them suggest something, and that is what they came up with and it worked like a charm. Did not have to cut anything.
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is offline   Reply With Quote
Old 05-01-2015, 10:00 PM   #10
Cool thank you galsofescape
