Old 09-13-2014, 07:39 AM   #1
First attempt at pop-up camping!
I just bought a 2007 Flagstaff 227 popup....my first trip is in a week (very excited). The trailer did not come with an owners manual so when I come across things I've usually been able to get the answers for this sight. Can anyone tell me if the interior lights are suppose to work, after unplugging from the truck and before plugging into the 120v?
Vicfut is offline   Reply With Quote
Old 09-13-2014, 07:44 AM   #2
Dennis and Julie's Avatar
Yes if you have a good battery.
Dennis and Julie
2018 Wildcat 28SGX
2013 Chevy Silverado 2500HD
2012 Chevy Silverado 2500HD
Dennis and Julie is offline   Reply With Quote
Old 09-13-2014, 07:45 AM   #3
ARLO
Is your battery not charging? Test the battery voltage and 12v output from the converter with a volt meter. You should be getting qabout 13.2 volts.
rlocicero is offline   Reply With Quote
Old 09-13-2014, 07:58 AM   #4
I had one of these. Great popups!
whitmw is offline   Reply With Quote
Old 09-13-2014, 08:06 AM   #5
I took the battery down to the auto shop and they tested it out, saying it was fine. I have a three way converter for the fridge but I have not checked it out yet....a little scared of propane! I checked the fuses and they were fine. Everything works when plugged to the house. I just can't get the sealing lights to turn on when not plugged into house power.
Old 09-13-2014, 08:25 AM   #6
Done with this
Our pop up had a micro switch so when the top was down, the lights wouldn't work and overheat causing a fire risk. Maybe that micro switch is bent or stuck? It is on the rail somewhere so the top will hit the switch when down...
I'm a little too truthful, I guess.
Y'all have fun in "Fantasy Land".
4mula1fan is offline   Reply With Quote
Old 09-13-2014, 08:27 AM   #7
RSchleder's Avatar
The frig may work as a 3 way item, however, that's just the frig design. The converter does 2 things in an rv, it coverts 120V AC to 12V DC ( which runs your 12V items when not plugged into 120V) and charges your battery/batteries. Your lights, when not plugged into 120V, get their 12V's from the battery which runs through the converter for distribution. So when you trouble shoot your ceiling lights, or any other lights for that mater, don't be concerned as the propane system is not involved. The above suggestions are the way to determine what's going on. If you don't have an volt/ohm meter, you can buy one at a reasonable price from any Auto store, Good luck!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 09-13-2014, 08:40 AM   #8
I know I have a switch that is located under the sink/stove area so that when I lift it into place it holds the red button down.....is that one in the same?
Old 09-13-2014, 08:45 AM   #9
Done with this
Not sure, but it could be worth a look. Our pop up was a high wall so it could be the same switch.
Old 09-13-2014, 08:47 AM   #10
Thanks everyone.....I'm sure I will be coming back often. HAPPY CAMPING
camping
