Old 05-02-2014, 01:16 PM   #11
gettawaydriver's Avatar
5. Another issue with lights might be the safety switch. With a popup there is a safety button or switch that must be made to run lights. Usually located somewhere on the galley with 2 wires to it. Sometimes it's bracket needs to be tweaked a bit to contact properly or a wire terminal might have popped off. It's a safety bc the lights get so hot they can melt stuff or cause fire if left on and trailer set down.
gettawaydriver is offline   Reply With Quote
Old 05-02-2014, 01:22 PM   #12
Did dealer sell you proper regulator? There are different models and styles. As well turn on the propane slowly. Modern tanks have a safety built in so that if there is a rush of propane out ( like initial line fill ) it will shut down the bottle internally.
Old 05-02-2014, 01:23 PM   #13
Originally Posted by Kaadk View Post
I doubt your battery was bad to start with, more likely you have a battery disconnect somewhere. In our TT it's next to the convertor. (Actually right about where your switch in question is). Most other people have them outside closer to the battery. Another possibility is the main line from the battery has an issue. Either fuse or current limiter (aka breaker) is popped. Trace from the battery back to see if anything is amiss.
Fuse on the battery line right outside the battery was busted. I'll try putting another in and see if that was the issue. Most likely is.
2008 Rockwood Freedom 2318G
2008 Dodge Caravan 4.0L
- Tow package
- Airlift 1000 air bags
- Curt Class III receiver (13364)
- Tekonsha 90160 Primus IQ Brake Control
dakranii is offline   Reply With Quote
Old 05-02-2014, 01:28 PM   #14
I am just prepping my pop up and doing some mods. Can't wait to get out, so I'm envious of you. Have a fun weekend and best of luck with the new popup.
Old 05-02-2014, 01:32 PM   #15
raspivey's Avatar
As to the controller.....read the directions ( and I'm not trying to be a jerk ). One setting won't be appropriate for all conditions, and having your trailer brakes lock up when you don't want them to isn't a good thing. Learn how to use it and adjust it whenever road conditions change. That needs to be something you don't have to think very much about.
Water.....I never drink the tank water. I will brush teeth with it, but that's about it aside from cooking with it (if I'm boiling it in the process). I take bottled water with me for drinking. It probably wouldn't hurt, but those tanks sit for quite a while even with sanitizing.
Old 05-02-2014, 04:03 PM   #16
2014 XLR 27HFS
LOL, welcome to camping! If you're not buying stuff to fix issues, then you're buying stuff to modify your toy. :-)
Dave & Audrey
dave961 is offline   Reply With Quote
first time
