Old 07-07-2011, 06:59 AM   #1
first time owner 2006 Flagstaff PUP
I just bought this popup a week ago and took it out this past weekend. Everything worked fine and we were pleased. However in raising the power lift there is a little grinding. I am guessing the cable needs to be lubricated. Does anyone have a similar problem?
Tblackman is offline   Reply With Quote
Old 07-07-2011, 08:19 AM   #2
tmmar's Avatar
Sorry I can't help you with your problem but wanted to congratulate you on your new camper and welcome you to the forums!! I'm sure someone here will be able to help you with your question.
Good luck!!
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 07-07-2011, 01:57 PM   #3
Moderators' Assistant
bikendan's Avatar
you might want to lube the supports first. are you sure it's the cable making the noise? could be the gearing system.
you should also post the model number of your popup, so that those who have the same model, can help.
Old 07-26-2011, 03:03 PM   #4
I had what sounded like a rubbing grinding sound when I first put up mine a month ago or so and found that lubricating the supports helped remedy the noise issue.
jamesw is offline   Reply With Quote
