Old 04-18-2015, 04:56 PM   #1
Fishhawk1650's Avatar
First upgrade of the year - Tongue Jack
The stock tongue Jack on my 2014 HW276 leaves a lot to be desired. It's small and quite wobbly. Contributing to this is that the stocker is a 2" Jack in a 2.25" frame opening. This causes the 2" Jack to wobble in the frame.Click image for larger version
Name:	ImageUploadedByForest River Forums1429394193.227541.jpg
I installed a Bulldog 2.25" Jack today and man I'm impressed!
For those considering the same, know that the A-frame Jack opening is a standard 2.25". This was my biggest unknown before ordering but eyeballing it from below with a tape measure looked like 2.25 and thankfully it was spot on.
A cheap $39 upgrade from etrailer.com is so worth it. Model used is BD155033.
Highly recommend it if you have also noticed the stocker Jack being flimsy.
Cheers
Dan
Fishhawk1650 is offline   Reply With Quote
Old 04-18-2015, 08:08 PM   #2
W4NT3D's Avatar
Very nice improvement, looks great.
2015 Rockwood HW296
2014 Silverado 1500 LTZ
W4NT3D is offline   Reply With Quote
Old 04-19-2015, 08:34 PM   #3
vinmaker's Avatar
I have noticed the stock one is wobbly. Is it a higher jack as well? Can you raise it higher?
Also. Any idea why the new one is more solid? What is the big difference?
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 04-19-2015, 08:49 PM   #4
vinmaker's Avatar
The reason I want a new front jack is because where I go every July the front is lower than the back so I need to crank it up high to level it. As the jack gets higher (longer extension) it gets more wobbly.
One of the comments on the etrailer site on yours is that the shaft below the mount is short. Could this be why mine is so wobbly? Looking at a Pro one , the shaft was longer so it is doubled up longer. I think this would help if fully extended.
Here is the link.
Compare Bulldog Round, vs Pro Series Round, | etrailer.com
Thoughts?
Vin.
2015 HW296
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 04-19-2015, 09:10 PM   #5
Hey Vin,
It raises just has high as the stocker so there shouldn't be any change there. One thing I noticed on the old jack, is if I wobble it, much of the wobble came from the 2" outer tube having play in the 2.25" opening. The rest of the wobble comes from the very thin inner tube. Moving to a sturdier 2.25" Jack installed into a 2.25" a-frame opening drastically reduces this.
I'm certain the stocker can accomplish the job for the life of the camper. It's a minor investment to bolster strength and sturdiness and ultimately less wobble by installing a Jack designed for the trailer it is being installed on.
The only wobble this Jack has that I've noticed is on the in on the foot. It comes from the side to side of the pin on the foot. Front to back is solid. If I remove the foot it is solid.
upgrade
