Old 05-25-2015, 07:35 PM   #1
GalsofEscape's Avatar
fixed the leaking low point drains
Those low point drains were always a pain to use. Every time we opened those drains, we could never get them to seat back down without a lot of finagling. They finally were leaking badly that we could not get to stop, so we changed them out.
Here are the old plastic ones
Name:	MOMTABLET - lowppoint drains.jpg
Here are the new brass sharkbite ball valve
Name:	MOMTABLET - new low point drains.jpg
Moved the lines a little forward so now the draining water does not hit the frame anymore.
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is offline   Reply With Quote
Old 05-25-2015, 07:50 PM   #2
vinmaker's Avatar
Wow. That is awesome. I cannot believe how cheap the drain valves are. I never saw anything so flimsy. I too was thinking about replacing them. Never thought about using ball valves. That is an awesome idea.
I have to remember where mine are. If I recall they are not easily assessable. Which is also stupid as one should have easy access to them.
You got my head thinking now.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 05-25-2015, 08:01 PM   #3
Thanks Vin, They were a pain to get to and we did not have a lot of room to work with. I really wanted to move the valves outside but that was not working out. So they remain inside but I am really happy with the way they turned out.
Old 05-25-2015, 08:13 PM   #4
Gals of escape where are urs located? Can't find any in my hw276 are they only for the outside kitchen?
kinma13 is offline   Reply With Quote
Old 05-25-2015, 08:16 PM   #5
No you should have low point drains, they are used to drain your water lines. Not sure where they are in your model. Mine are in the back (rear)most cabinet. That just happens to be where my slide out kitchen is located.
Old 05-25-2015, 08:18 PM   #6
vinmaker's Avatar
I think mine are under where the TV is mounted. I have to remove a cabinet board. It is screwed shut so you can tell it is not a part of the normal cabinet construction which would have hidden screws or staples. If you take off the board you can see the drain valves. They did the same thing with my hot water heater. It is behind a board that is screwed on. I have to take that off to reach the bypass valves when I winterize it.
2015 HW296
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 05-25-2015, 08:19 PM   #7
Fishhawk1650's Avatar
Kinma, they should be located in the cupboard located on the floor and to the right of the range/oven on a 276.
That's a beautiful mod and definitely will go for this if they start acting up. Thank you for sharing!
Fishhawk1650 is offline   Reply With Quote
Old 05-25-2015, 08:21 PM   #8
Egads, how inconvenient. You would think they would make these types of things accessible since you have to get to them.
Old 05-25-2015, 09:13 PM   #9
Do I only need them when winterizing? I just flushed the antifreeze out and sanitized the tank n lines but nothing was dripping under the pup? Dealer winterize last yr for me. I'm thinking they need to be closed to hold the anti in
Old 05-25-2015, 09:21 PM   #10
You would also use them to dewinterize to flush the lines free of antifreeze or any time you want to flush or sanitize the lines. You pull up on the valve to open, open a faucet and the water drains to the ground. Push down on the valve to close it.
drain, leak
