Old 05-26-2015, 12:29 PM   #1
Question Fixing Cracked Roof Corners
All of the corners of the roof are cracked, though only one has separated down to the bottom. What is the best way to repair them, and why does this happen?
OutOfTheTent is offline   Reply With Quote
Old 05-26-2015, 12:36 PM   #2
Ret E-9 Anchor-clanker
donanddona's Avatar
Could you post some pictures. Not sure on direction of cracks and depth too.
donanddona is offline   Reply With Quote
Old 05-26-2015, 01:23 PM   #3
[img=http://s5.postimg.org/6wbs5tycn/Pup_Roof_1.jpg]
Old 05-26-2015, 01:27 PM   #4
share image
Old 05-26-2015, 01:28 PM   #5
I have a bad feeling about this, which is that it is caused by the top of the bottom part of the pup loosening up, creating a larger perimeter.
Old 05-26-2015, 08:42 PM   #6
I know you can order replacement corners, I had to replace a couple on my last pop up. The hard part was removing the old chalk, I used a one part urethane when I installed the new corners, not sure it was the right caulk to use but I've had good results on other projects. Regarding the separation , there usually are metal corner brackets on the inside of the roof, perhaps the screws holding them have loosened or rusted away, allowing the corner to separate. I don't think you have a big problem, but you never know, Good luck
GB guy is offline   Reply With Quote
roo, roof
