I know you can order replacement corners, I had to replace a couple on my last pop up. The hard part was removing the old chalk, I used a one part urethane when I installed the new corners, not sure it was the right caulk to use but I've had good results on other projects. Regarding the separation , there usually are metal corner brackets on the inside of the roof, perhaps the screws holding them have loosened or rusted away, allowing the corner to separate. I don't think you have a big problem, but you never know, Good luck
