Old 05-08-2011, 10:02 PM   #11
Herk7769's Avatar
Originally Posted by sherdep View Post
she has a single bottle so that blows your theory out the window on the double bottle scenario
The problem could still be in the bottle, not the selector or pigtail. I just use that technique to shorten the run from the switch to the bottle in my 5th wheel as the "reserve" tank is on the other side of the camper with an 8 foot hose to the switch. It is not a requirement.
Close the valve. wait a few minutes. SLOWLY open the knob as I stated in my previous post. It took me several times before I got it right. If you just spin the knob open you will trip the check valve regardless how many tanks you try.
HAM CALLSIGN - KC3FFW
Old 05-08-2011, 10:34 PM   #12
Man I learn so much from these forums... Next time I have difficulties getting my fridge or furnace to light, which has been every outing so far, I am purging the lines by lighting the stove first. Ingenious!
Kurt, Brenda & Sara
Maricopa, AZ
2010 Flagstaff 228D + 2010 Ford 150 XLT 5.3 4x4
Nights Camped Total = 13
kharless is offline   Reply With Quote
Old 05-09-2011, 11:13 AM   #13
I spoke to the dealer today and they suggested blowing out the lines, so I'll try that next and let you know..
ps...Julian is a male....haha
Julian is offline   Reply With Quote
Old 05-09-2011, 11:43 AM   #14
Herk7769's Avatar
DO NOT DO THAT!
If you use compressed air in the propane lines you will make sure the dealer can send his kids to college on your dime.
Even with low pressure you can burst the regulator and/or clog all the jets in your appliances.
I burst two regulators trying to troubleshoot mine. Turned out I had a bad pigtail and by trying to "blow it out" I destroyed my propane system. I had to replace the bad pigtail, the red high pressure regulator on the driver side AND the switchover regulator with both check valves.
A word to the wise.
Old 05-10-2011, 04:19 PM   #15
Thanks for all your help folks. The problem is solved. It seems that when I cranked the propane tank open fully, it tripped the overflow regulator. Today I open the tank slowly with just 32 turns and the propane is flowing beautifully.
Thanks again for all your help and suggestions.
Old 05-10-2011, 04:39 PM   #16
MtnGuy's Avatar
Huh ?? My valves only turn about 2 times before they are fully open.
Old 05-10-2011, 04:50 PM   #17
Herk7769's Avatar
Bada Bing.
I will be here all week; try the Veal.
Old 05-10-2011, 05:39 PM   #18
sherdep's Avatar
sorry for calling you a she - Doh - thats what I get for assuming
Glad you got it figured out and back to grilling again
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 05-10-2011, 08:40 PM   #19
Hi All
I made a typo...it should have read "turned the valve 2 times" not 32......I wrote that after working my nightshift, so I was have in the bag anyway......but, I'll be in Algonquin Park at the end of the month with heat and a bbq and that's all that's important.
Old 05-11-2011, 06:57 AM   #20
MtnGuy's Avatar
Hi All
I understand about that night shift stuff....been there, done that.
