Old 04-22-2011, 06:01 PM   #1
Flagstaff 227 electric problem
Hi,
the inline fuse blows every time I change the fuse 20A.
any idea?
what device is controlled by the inline fuse?
Flagstaff 227 2008
Elricko is offline   Reply With Quote
Old 04-25-2011, 08:33 PM   #2
RONSTAR911's Avatar
Is it the Main fuse from the Battery? If so all of your lights, appliances etc are running from that fuse. The only way to figure it out is to disconnect one fixture at a time and see which one stops blowing the fuse.
BUT first follow the wire along the frame and look for worn insulation on the wire, this will happen if its rubbing against something for a long Time.This visual inspection is the first thing to do, if you find a worn spot either tape it up or replace the wire and ensure there is no more bad spots that can short out the fuse.
Hope this helps! ]
Ron Y
Delta BC
RONSTAR911 is offline   Reply With Quote
Old 04-25-2011, 10:47 PM   #3
Elricko, you need to be a little more specific about what fuse it is, and what goes off when it does blow. The inline fuses on my unit are in a green plastic holder, and are 30 amp fuses for the electrically operated slide outs. There is also a relay/ junction block under the tongue area that the battery wire goes to that can go bad easily. If it is in the converter fuse box area, it could be any number of things, depending on the fuse. Be SURE your battery is wired correctly, and the electric water heater switch outside, under the access panel is off. It should not be too hard to pinpoint the problem. Randy
Old 04-26-2011, 10:26 PM   #4
RE:
Hi,
The inline fuses on my unit are in a RED plastic holder and are 20 amps.
I dont have a slide outs and a electric water heater.
Now I know the light not work in 12 volt with 120 ac is work
My next step is:
what RONSTAR911 propose:
thank you for your ideas
Old 05-15-2011, 01:27 PM   #5
I found the problem
The solution is :
The small black wire with inline fuse go to + born
The big white wire go to - Born.
Old 05-15-2011, 02:13 PM   #6
bikendan's Avatar
Originally Posted by Elricko View Post
The solution is :
not sure what "Born" is but are you saying the wires to the battery were reversed?
227, inline fuse
