Old 01-07-2014, 04:10 PM   #1
Flagstaff Beeping
Hi!
I have a forest river flagstaff popup trailer. The beeping is driving me and my dog bananas. I have unhooked the battery, pulled the smoke detector batteries out, shut down the circuit breaker on the power converter and pulled the fuses. It is still beeping. I can't figure out where the beeping is coming from. I think I am close to the sound...but then I don't find anything.
Help!
adamscabana is offline   Reply With Quote
Old 01-07-2014, 04:21 PM   #2
Fulltime family RVer
LP detector?
Old 01-07-2014, 04:25 PM   #3
cat1956's Avatar
Do you have a LP detector? It will be close to the floor and it has a inline fuse so pulling fuses want stop it. If that is it take the screws out and take your inline fuse out. Replace LP detector if it is bad.
cat1956 is offline   Reply With Quote
Old 01-07-2014, 04:26 PM   #4
I pulled the battery out of the smoke detector. i'm still pretty new to the camper. Where is the LP detector? I see the co2 detector, but it doesn't have a battery.
I hooked everything up and plugged it in...hoping a charge would help.
Old 01-07-2014, 04:27 PM   #5
i'll check for the inline fuse.
Old 01-07-2014, 04:43 PM   #6
cat1956's Avatar
Mine will beep if the camper battery is low on charge.
Old 01-07-2014, 05:16 PM   #7
I unscrewed the co2 detector and pulled the in line fuse. I still hear the beeping.
Next I unplugged the battery and flipped the breakers to off on the power converter. I still hear beeps.
I had plugged in the trailer this morning to see if getting a charge would stop it help...but it still beeped.
It sounds weird, but with the battery hooked up it seemed to beep more frequently. it seems like it may be a little longer between beeps now.
If I am inside of the trailer and turn to the left (facing the back of the trailer) the co2 detector is on the floor on the right. It doesn't sound like that is making any noise. It sounds like it is coming from the back left. I don't know what is back there to beep.
Old 01-07-2014, 05:22 PM   #8
The only thing I can think of is the fan on the ceiling. But that doesn't have its own fuse/power does it?
Old 01-07-2014, 05:57 PM   #9
cat1956's Avatar
I don't know what to tell you. Maybe someone else will chime in that knows more.
Old 01-07-2014, 06:44 PM   #10
caper's Avatar
The detector by the floor is most likely the LP detector. You might have a CO detector at the other end. The CO detector might look similar to a smoke detector.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
flagstaff
