If you are talking about an A-frame pop-up, there is a separate forum for the A-frames. You might have the moderators move your thread. The electric lift system on the A-frames has been an issue, and there have been several threads on fixing it.
On my 2019 Flagstaff T21TBHW, the dealer claims Forest River has finally fixed the problems. We shall see. My A-frame is stored inside the garage, so I should have less problems with dust, dirt, and water intrusion. The lift motor now plugs in to a jack on the side, so replacement would be easy if necessary. The seals and the size of the motor have been improved, and the gears are now all metal.
If you can get a replacement from Forest River, make sure you get the new one.
just my thoughts and experiences
Fred W
