Old 01-15-2015, 06:08 PM   #1
Sand D
Flagstaff HW27SC 2014 door gap
We have a Flagstaff HW27SC 2014, anyone have issues with the main door having a 1/4" gap in the top of the door and the bottom of the door not staying in place? Camping World did warrenty work on the screen door portion (the frame complety fell apart) and when we got it back noticed the gaps, trying to find out if those were there before or after?
Sand D is offline   Reply With Quote
Old 01-15-2015, 08:00 PM   #2
rbblair's Avatar
We have the same year and model. Are the gaps between the door and frame or the door frame and the PUP doorway? If the gaps are between the door frame and PUP door opening it is usually do to the fact that the PUP is not level. Try leveling the PUP to the door frame and don't use the levels as the only guide.
rbblair is offline   Reply With Quote
Old 01-15-2015, 08:01 PM   #3
HONDAMAN174's Avatar
Is it the frame that you are talking about? We always had issues at the top where the frame meets the roof- gave up trying to clip the top clips cause of the roof always moving/leaning with awning.
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
Old 01-17-2015, 07:49 AM   #4
vinmaker's Avatar
You need to measure the opening of the door space without the door in it. Measure the bottom gap by the floor and then measure the top. They should be very close. If they are not, then the frame is out of alignment and might have bent a bit. It may not be the door frame but rather the pop up frame.
Good luck.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
flagstaff, door, 2014
