Old 01-01-2018, 08:36 PM   #1
Flagstaff tent camper door
We purchase a tent camper, a 2018 Flagstaff Bh228ES I think it is, anyway, the door will not close properly to latch. We removed the half door, made sure everything was level and still, will not close! Had to sleep with it flying open all night on a 29 degree night.
We tried everything we could think of. Any suggestions?
We are newbies, but do not lack common sense. It just wont latch. Its the first time weve ever camped in a camper of any kind.
Thanks.... and Happy New Year!!
CollierDuo is offline   Reply With Quote
Old 01-02-2018, 09:13 AM   #2
Pinn's Avatar
Pictures will help us.
2013 Flagstaff 27RLWS - Chole'
NC
Pinn is offline   Reply With Quote
Old 01-02-2018, 09:33 AM   #3
exploreco's Avatar
All I can suggest is to check to make sure your fully extended, or not extended too far. Also check and make sure your stabilizers are good and steady. Not too much, but not loose. Any time I have any issues with my door it is usually one of those issues. Never had it not completely shut, but have had it close tightly before.
2014 Rockwood Premier 2514G
2010 Ford F150 Lariat
Nights Camped in 2018-12
2017-29, 2016-33, 2015-22, 2014-22, 2013-20
exploreco is offline   Reply With Quote
Old 01-02-2018, 09:40 AM   #4
cavie's Avatar
Make sure your level. Is the latch unlocked???? I have a motorcycle with a kill switch. That's why I ask these kinds of questions. Been there, done that.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 01-02-2018, 01:41 PM   #5
Hoyt15's Avatar
I have had the same issue with my 2017 gr8 206ltd. After many re leveling and other things. I noticed the roof was a little to high, I lowered to watch the top and bottom half of Dr come together
That seem to work, now I have set the upper and lower limit switches. Hope this helps.
Hoyt15 is offline   Reply With Quote
Old 01-02-2018, 03:16 PM   #6
jwh4984's Avatar
The awning can cause issues with roof and the door
jwh4984 is offline   Reply With Quote
Old 01-02-2018, 03:28 PM   #7
Scoundrel
HangDiver's Avatar
On my previous tent camper when I lowered the stabilizers at each corner of the frame it would sqeeze and distort the door frame & the door wouldn't shut.
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller
Wooden Spoon Survivor
HangDiver is online now   Reply With Quote
Old 01-02-2018, 03:44 PM   #8
Flagstaff TT Door
Have an 2018 Forest River RV Flagstaff High Wall HW27SC
As others have indicated level, level, level. A little out of level ends up being allot by the time it gets up to the door, joints and door frame.
But leveling the camper body isn't the only place... the extended top can be slightly off for any number of reasons. Not up all the way, up too far, one of the metal extenders slightly up or down from the others. The canvas top pulled too tight. Doesn't take much to pull it out of square.
These are real PIA Doors. Were not designed by an engineer that knew about TT camping, take down and put up repeatedly.
Try adjusting the door frame and door before getting all the Velcro in place and everything tied in and stretched. It isn't an exact science... sometimes it goes in and fits perfect, other times I want to put the door in the dumpster! They should design it with better fit and easier installation. But cheap is where their minds are at.
rlh1957 is offline   Reply With Quote
Old 01-02-2018, 07:17 PM   #9
Hoyt15's Avatar
Amend on what rlh1957
Old 01-03-2018, 09:43 AM   #10
There's a little spring inside lock mechanism that might not be aligned or seated properly.Door will not latch if this is the case.
Kayak is offline   Reply With Quote
camper, door, flagstaff, tent camper
