Old 06-10-2015, 06:54 PM   #1
Floor holes?
I crawled under my pup and where hoses and lines go up in the inside there was good sized holes. What can I fill these with? I was thinking spray foam?
lakecumberland is offline   Reply With Quote
Old 06-10-2015, 06:58 PM   #2
Try some copper mesh around the holes and fill with foam. Mice will have a hard time getting in.
Jerry. Vietnam vet.
Retired
jgahlhoff is offline   Reply With Quote
Old 06-10-2015, 07:19 PM   #3
Copper mesh?
Old 06-10-2015, 07:28 PM   #4
George & Lisa
George_Lisa's Avatar
Use a 35 year silicone $6 at a hardware store,mice wont get through it and it will be a good seal.
2006 R-Vision 18' Bantam Flier
2005 Chev Blazer 5speed
George & Lisa
Nights Camped- 2015.... 25 nights
Nights Camped- 2016.... 2 so far
George_Lisa is offline   Reply With Quote
Old 06-11-2015, 08:31 AM   #5
exploreco's Avatar
I used silcone to fill any holes underneath that I found. Also, double check around all areas of the camper where any type of silicone is used. I found two air pockets that needed filled around my storage bin that would have leaked water while traveling in the rain. Just things that happen during the quickness of the manufacturing process.
2014 Rockwood Premier 2514G
2010 Ford F150 Lariat
Nights Camped in 2018-??
2017-29, 2016-33, 2015-22, 2014-22, 2013-20
exploreco is offline   Reply With Quote
Old 06-11-2015, 08:38 AM   #6
Charliec's Avatar
I use steel wool.
Charlie C
2012 Ford F-150
2015 Rockwood 2504S
Charliec is offline   Reply With Quote
Old 06-11-2015, 08:39 AM   #7
Originally Posted by Charliec View Post
I use steel wool.
Reason?
Old 06-11-2015, 09:48 AM   #8
f5moab's Avatar
In TN, neighbor owned an exterminating company; his suggestion would be expandable foam and steel wool. Seems mice don't like chewing on metal (they destroy copper...my experience using copper mesh), but steel wool rusts. So what he would do to close up holes in houses, was to foam one side, go to the other side, fill it with steel wool, then seal up that side with the foam. Or shove the steel wool into the home and then foam on both sides.
I did that and the mice didn't come through the hole again. They had actually chewed through some of the foam, but stopped. Then they went and found another hole to come in through. Learned that living in the country, with fields all around, it was next to impossible to keep the little buggers out, but a few weeks after the cold spell and after they moved in, good traps took care of the problem, till the next fall.
f5moab is offline   Reply With Quote
Old 06-11-2015, 01:05 PM   #9
Charliec's Avatar
As f5moab said, they won't chew on it. I use it at all holes as well as on my slide out where there are always holes when they are closed. It will fall out many times when I open the slide so I keep several packs onboard for replacement when necessary. It will rust as stated but I just replace it.
Charlie C
2012 Ford F-150
2015 Rockwood 2504S
