Old 02-29-2016, 07:43 AM   #11
f5moab's Avatar
Nice idea!
f5moab is offline   Reply With Quote
Old 02-29-2016, 08:47 AM   #12
Originally Posted by sallystrothers View Post
How much steel are we talking? Did you weld the steel to the beams and then bolt the step to the steel?
No. i just bolted the flat steel 2" wide strips to the front beam that your current step is bolted to, and also to the next beam over that your current step is also bolted to. Once the steel straps spanned the 2 beams, i then bolted my new steps to the straps. So what you end up with is, you run your bolts up through your new steps front bracket then through the camper's beam then through the steel stripes. Then for the rear mounting of your new steps you bolt through where ever they line up your spanned steel stripes . Mine lined up about half way in. between the camper beams. Just make sure the flat steel you buy is thick enough. I think i used 1/4" steel 2" wide. for lenght just cut them to fit in between the beams.
2013 Rockwood popup 2318 g. TV 2003 trailblazer and a 2013 SLE Sierra p/u
campfire joe is offline   Reply With Quote
Old 03-02-2016, 08:04 PM   #13
I ended up getting a double step from etrailer. One of their 24" steps was actually closer to fitting on the brackets than their 20" step so I went with the 24". Guess I will try to sell my single step for a couple of dollars. Any issues with the extra torque on the frame when standing on the bottom step?
sallystrothers is offline   Reply With Quote
Old 03-03-2016, 08:10 AM   #14
f5moab's Avatar
Which MAC do you have? And which step did you get, do you have a number? Thanks to getting old and the knees hating that step down onto the dirt, been thinking of going to a double step.
Old 03-03-2016, 09:35 AM   #15
The extra torque is well-absorbed by the frame and stabbers. We don't notice any more movement than with the single-step.
And of course the double's don't match up underneath like the single's do. They must plan this stuff ahead of time! To mount my new double, I made mounting brackets from the sides of the single. If you want to do that, look at the long channel used by the single step to glide in and out. Hacksaw the 'meat' off each end of the channel and presto, instant mounting brackets are in your hand for the double. A welder charged me $50 to weld the brackets to the double, even painted 'em for me.
Camping in the Pacific NW
2014 Flagstaff MAC 206st
CappyHamper is offline   Reply With Quote
Old 03-03-2016, 06:36 PM   #16
I have a 228BH. The number is LC341500. The dimensions of this step match much closer to the brackets than their other steps when I measured. With free shipping it's not a bad deal.
Old 03-06-2016, 08:04 AM   #17
installation was fairly straightforward. The front right bolt needed to be re-drilled about an inch further and I bolted a piece of 1/8" angle iron across the two beams for the back bolts. Only potential issue I see is with tire clearance. I have 25" OD tires and there is about 2" clearance to the stair (it hangs down further than a single step) which means the biggest tire I can put on is probably 28". I wonder how much clearance is actually needed to the tire? It's not an issue with the leaf spring travel either, the 2" is the worst case even if the springs were fully compressed.
