Old 02-25-2016, 10:11 PM   #1
Folding step add-on to single step?
I noticed my single step has two holes on each side drilled for what I presume to be a double step. Anyone know where I can find a single folding step to bolt on to my existing single step to make a double step? I've searched unsuccessfully on the web. I'm trying to make a double step for as cheap as possible.
sallystrothers is offline   Reply With Quote
Old 02-26-2016, 06:00 AM   #2
I could be wrong, but I'm not sure if that's possible. Your best and probably safest option would be just to buy a new double step. I have double 20" Flexco steps that are bent and want to replace. A new set is less than $100 and looks pretty easy to bolt on. I think there's only four bolts. Check your step manufacturer's site as well as etrailer.
spurticus is offline   Reply With Quote
Old 02-26-2016, 10:52 AM   #3
I agree there's no easy bolt-on solution. The double's run wider than stock single-step. I found this unit online but had to modify a bit to fit my MAC 206st:
Robot Check
Total cost was $150. Well worth it for us since our dirt-to-first step was 13" on level ground, & even higher on sloping terrain. If you want instructions I'm happy to share specifics.
Camping in the Pacific NW
2014 Flagstaff MAC 206st
CappyHamper is offline   Reply With Quote
Old 02-26-2016, 08:53 PM   #4
Do stairs measure to the inside width of the stair? I believe I measured the outside edge at 20 1/4.
Old 02-27-2016, 12:43 AM   #5
Fulltime family RVer
I've been looking for a step that hooks onto the one that is already there. I found one vendor, but they want like $150 for this add-on and that's too rich for my "gifting to a friend" blood.
ependydad is online now   Reply With Quote
Old 02-27-2016, 12:07 PM   #6
Seems there are not many RV junkyards around, thought I might be able to get a step and then frankenstein it onto my step.
Old 02-27-2016, 12:15 PM   #7
Left Coast
Google RV Surplus Parts
Old 02-28-2016, 08:31 PM   #8
I put a double step on mine, and like has been said there is adjustments that have to be made. The new step was a little wider, not a big problem just drill another hole. The biggest problem was the depth of the new one it wouldn't span to my next i beam. So i had to buy 2 pieces of flat steel to span the distance, and then bolt the new steps to the flat steel.
2013 Rockwood popup 2318 g. TV 2003 trailblazer and a 2013 SLE Sierra p/u
campfire joe is offline   Reply With Quote
Old 02-28-2016, 10:20 PM   #9
How much steel are we talking? Did you weld the steel to the beams and then bolt the step to the steel?
Old 02-28-2016, 10:29 PM   #10
I made an add on step for Ms. April (Bombdoc's DW). Supposedly it works fine and is also adjustable.
Name:	April's unpainted step.jpg
ID:	100707   Click image for larger version
Name:	April's painted step.jpg
