Old 09-11-2014, 05:24 PM   #1
Fridge not working
I have a 2280 trailer with a domestic fridge. I have it plugged in to a/c at home and the fridge is not working. There are no controls on the fridge. Any advice would be welcome. Thanks
fastdog is offline   Reply With Quote
Old 09-11-2014, 05:31 PM   #2
There is a reset on the chimney that might have tripped. Push the little red button and see if it snaps.
Name:	Refrigerator Overheat sensor.JPG
Old 09-11-2014, 05:34 PM   #3
Sorry to be stupid, but where is this chimney.
Old 09-11-2014, 05:41 PM   #4
You need to remove the outside vent cover for the refrigerator. The chimney will be the round metal tube above the burner. There might also be a black box back there which contains fuses. If there is check those too.
keith_h is offline   Reply With Quote
Old 09-11-2014, 05:44 PM   #5
Open the outside door to the frig compartment and it is at the end of the burner.
Old 09-11-2014, 05:45 PM   #6
Found the chimney and the red button did snap. Finger crossed. Thanks Keith
Old 09-11-2014, 05:46 PM   #7
Thanks Old Coot for the picture.
Old 09-11-2014, 05:49 PM   #8
Glad to be able to shed some light on the subject, however dim the light is.
Old 09-12-2014, 10:31 AM   #9
No luck. Fuses seem ok. Red button always snaps. Any more advice. Thanks
Old 09-12-2014, 11:48 AM   #10
What is the model of the fridge?
Can you get it to cool on propane?
Old 09-12-2014, 01:11 PM   #11
No model # on fridge. Found a ground fault that had popped will see if that works, then I'll try propane. Thanks
Old 09-15-2014, 05:56 PM   #12
Actually, the controls should be in the same section (or the section above) where you accessed the chimney (behind the fridge, accessed from the outside). Somewhere in there should be a switch for AC and one for DC. The more recent fridge models also have a rotary control to set for the amount of cooling on AC, similar to the one near the bottom for propane.
But the newer, bigger, heavier PUPs (especially high walls) tend to have fridges more like travel trailers - so the model is important. Find the model number and do an internet search - the operator's manual should have instructions as to what all the controls look like and how they work. Again, most PUPs have all the controls behind the fridge, and accessed by removing or opening an outside access panel(s).
Fred W
Old 09-15-2014, 06:22 PM   #13
IF the red button snaps, you have an electrical problem with the button assembly itself. It is a thermal protection device and very well could be defective.
Old 09-23-2014, 05:33 PM   #14
Found out the fridge had not been used in years. It took about 24 hours for it to get cold. thanks for everyones help.
Old 09-23-2014, 06:19 PM   #15
That's not unusual. I have to start my fridge the day before we leave to get it to temperature and stable.
Old 09-23-2014, 07:15 PM   #16
Thanks Keith. Feel better now.
fridge
